Yoast SEO Title Name Repeated
DCND
DCND posted this 01 January 2015
Not sure if this is a bug or a setting. I have created 2 sites and I noticed when I use the plugin Yoast SEO for wordpress that the sitename gets appended twice at the end of the website title. I have 2 examples of Themler sites I am developing and noticed it. The only way I can get rid of it is by taking away the sitename in settings. I am also overriding the title in Yoast for the individual pages. I am not sure what is triggering it. What I have found is that you had to modify the header.php for normal themes, however I noticed in themler they are pretty complicated and did no know where to start.
http://www.dcnd.com/swl
http://www.vegasroaches.com
Both are examples. Also you will notice that for some reason on Vegasroaches if you go to the home page or contact page is is messed up with the title being appended at the end. But if you pull up the How To Information it is right. Both pages are using the frontpage template and changing it to Page template did nothing. Both are pages so and have similiar settings for Yoast so I am not sure.
I use Yoast with no problems in the past with other templates made in Artisteer so I am not sure what is going on. If you need access let me know.
Brian
Not sure if this is a bug or a setting. I have created 2 sites and I noticed when I use the plugin Yoast SEO for wordpress that the sitename gets appended twice at the end of the website title. I have 2 examples of Themler sites I am developing and noticed it. The only way I can get rid of it is by taking away the sitename in settings. I am also overriding the title in Yoast for the individual pages. I am not sure what is triggering it. What I have found is that you had to modify the header.php for normal themes, however I noticed in themler they are pretty complicated and did no know where to start. http://www.dcnd.com/swl http://www.vegasroaches.com Both are examples. Also you will notice that for some reason on Vegasroaches if you go to the home page or contact page is is messed up with the title being appended at the end. But if you pull up the How To Information it is right. Both pages are using the frontpage template and changing it to Page template did nothing. Both are pages so and have similiar settings for Yoast so I am not sure. I use Yoast with no problems in the past with other templates made in Artisteer so I am not sure what is going on. If you need access let me know. Brian
21 Comments
Support Team posted this 03 January 2015
Have you switched to the default WP template? Does it give the same effect?
Also, you say:
So previously you have done some modifications in the WP templates? If that helps, you can provide the instructions here and we'll try to find out where it should be done in Themler themes.
Hi, Have you switched to the default WP template? Does it give the same effect? Also, you say: >What I have found is that you had to modify the header.php for normal themes, however I noticed in themler they are pretty complicated and did no know where to start. So previously you have done some modifications in the WP templates? If that helps, you can provide the instructions here and we'll try to find out where it should be done in Themler themes. Sincerely, Hella BillionDigital Team
DCND
Is Solution
DCND posted this 03 January 2015
Well I looked through and found that there is a setting in Yoast that I had to set. Under SEO->Titles&Meta
be sure to check "Force ReWrite Titles"
Even though by default Yoast will determine if it needs to be checked or not and it did not check mine, I had to. If I switched to a default theme and any non themler theme it still worked fine. I just had to check that box for my themler them.
Hopefully this will help anyone else. If you want to look into this more let me know I can help provide information.
If you want to make this public be my guest.
Well I looked through and found that there is a setting in Yoast that I had to set. Under SEO->Titles&Meta be sure to check "Force ReWrite Titles" Even though by default Yoast will determine if it needs to be checked or not and it did not check mine, I had to. If I switched to a default theme and any non themler theme it still worked fine. I just had to check that box for my themler them. Hopefully this will help anyone else. If you want to look into this more let me know I can help provide information. If you want to make this public be my guest.
Support Team posted this 05 January 2015
Hello Brian,
so the issue is solved. If you need any further assistance please let us know.
I'm making this post public to share the solution with other users.
Hello Brian, so the issue is solved. If you need any further assistance please let us know. I'm making this post public to share the solution with other users. Regards, Aileen
searchmelocal2
searchmelocal2 posted this 25 September 2024
Unlock the full potential of your business with SearchMeLocal’s premier SEO services! At https://searchmelocal.com/seo-for-dental, they understand the vital role that online visibility plays in today’s competitive market. Their SEO experts are dedicated to optimizing your digital presence, ensuring that your business stands out in local searches and reaches its target audience effectively.
flwplmzyp1
flwplmzyp1 posted this 25 September 2024
Unlock your business's potential with Monkey Mart by utilizing SearchMeLocal’s premier SEO services! Visit to enhance your online visibility. Their SEO experts focus on optimizing your digital presence, helping your business shine in local searches and connect effectively with your target audience.
Unlock your business's potential with [url=https://monkeymart.one/]Monkey Mart[/url] by utilizing SearchMeLocal’s premier SEO services! Visit to enhance your online visibility. Their SEO experts focus on optimizing your digital presence, helping your business shine in local searches and connect effectively with your target audience.
iskillpractise
iskillpractise posted this 25 September 2024
Terabox is a storage service app that gives users 1TB of free space, There are some Terabox mod apk alternatives to the Terabox app. These Terabox mod apk alternatives provide you with some features like video, photos, and large file uploads. If you’re looking for some great alternatives to Terabox, check out the list of storage apps below we provide you with some information about them
Terabox is a storage service app that gives users 1TB of free space, There are some Terabox mod apk alternatives to the Terabox app. These [Terabox mod apk alternatives][1] provide you with some features like video, photos, and large file uploads. If you’re looking for some great alternatives to Terabox, check out the list of storage apps below we provide you with some information about them [1]: https://proterabox.com/terabox-mod-apk-alternatives/
strange.tortoise.snzm
strange.tortoise.snzm posted this 12 April 2025
Responding to the question about alternatives to Terabox, you're essentially seeking convenient and feature-rich ways to manage your digital life. Just as Terabox offers cloud storage, the internet has many options to help. If you want to chat with people without sharing personal information you can use Omegle, Omegle is a free online chat platform. For a different kind of connection, explore spontaneous conversations and meet new people on omegle
via https://omeglechat.online/.
Responding to the question about alternatives to Terabox, you're essentially seeking convenient and feature-rich ways to manage your digital life. Just as Terabox offers cloud storage, the internet has many options to help. If you want to chat with people without sharing personal information you can use Omegle, Omegle is a free online chat platform. For a different kind of connection, explore spontaneous conversations and meet new people on [omegle](https://omeglechat.online/) via https://omeglechat.online/.
Abbas Khan
Abbas Khan posted this 23 May 2025
Another powerful advantage of Remini Mod APK is its frequent updates and continuous improvements. The developers behind the original Remini application are consistently refining the AI model to make it even more effective at detecting and correcting flaws in images. These improvements carry over into the remini pro mod apk, ensuring users get the best performance every time they enhance a photo.
Another powerful advantage of Remini Mod APK is its frequent updates and continuous improvements. The developers behind the original Remini application are consistently refining the AI model to make it even more effective at detecting and correcting flaws in images. These improvements carry over into the **[remini pro mod apk][1]**, ensuring users get the best performance every time they enhance a photo. [1]: https://modremini.in/
yfe49631
yfe49631 posted this 07 October 2025
The CIPM Dumps requires thorough understanding of privacy program governance and operational management. Guide4sure's question bank thoroughly covers essential topics including privacy program leadership, organizational structure development, and accountability mechanisms. Through detailed scenario-based questions, you'll develop the skills needed to establish and maintain effective privacy programs that align with business objectives while ensuring regulatory compliance across global jurisdictions.
The **[CIPM Dumps][1]** requires thorough understanding of privacy program governance and operational management. Guide4sure's question bank thoroughly covers essential topics including privacy program leadership, organizational structure development, and accountability mechanisms. Through detailed scenario-based questions, you'll develop the skills needed to establish and maintain effective privacy programs that align with business objectives while ensuring regulatory compliance across global jurisdictions. [1]: https://www.guide4sure.com/CIPM-release.html
muntahaseo71
muntahaseo71 posted this 27 December 2025
South Dublin Dental appears to be a well-equipped and patient-focused dental practice. Its convenient location with ample parking, early opening hours, and acceptance of both PRSI and private patients make it highly accessible. The practice’s focus on advanced treatments like root canals and dental implants, along with full hygiene services and a fully digital setup, reflects a modern and comprehensive approach to dental care.
[South Dublin Dental][1] appears to be a well-equipped and patient-focused dental practice. Its convenient location with ample parking, early opening hours, and acceptance of both PRSI and private patients make it highly accessible. The practice’s focus on advanced treatments like root canals and dental implants, along with full hygiene services and a fully digital setup, reflects a modern and comprehensive approach to dental care. [1]: https://southdublindental.ie/
naveedxheikh791
naveedxheikh791 posted this 06 January 2026
Simply put, an Alight Motion template (often shared as an XML file or a project link) is a pre-edited project file. It contains all the layers, effects, transitions, and animations already set up by a creator.
Simply put, an [Alight Motion template][1] (often shared as an XML file or a project link) is a pre-edited project file. It contains all the layers, effects, transitions, and animations already set up by a creator. [1]: https://themotionalight.com/alight-motion-templates-free-xml/
sijef42531
sijef42531 posted this 15 January 2026
Trusted Developers support from a leading Recruitment Agency in Greater London, helping companies hire top & talented Developers while guiding professionals to the right IT opportunities for long-term success. We support businesses across industries that hire Developers and are connected to teams and operations associated with Greater London.
Trusted Developers support from a leading [Recruitment Agency in Greater London][1], helping companies hire top & talented Developers while guiding professionals to the right IT opportunities for long-term success. We support businesses across industries that hire Developers and are connected to teams and operations associated with Greater London. [1]: https://hirewebcreators.co.uk/greater-london/
sijef42531
Our services help businesses across West Midlands find the right talent quickly and efficiently. As one of the leading recruitment Agency in West Midlands, we streamline the hiring process while providing full support to both companies and candidates. Recognised as one of the top recruitment agencies in West Midlands, UK, we make hiring seamless and stress-free for every organisation.
Our services help businesses across West Midlands find the right talent quickly and efficiently. As one of the leading [recruitment Agency in West Midlands][1], we streamline the hiring process while providing full support to both companies and candidates. Recognised as one of the top recruitment agencies in West Midlands, UK, we make hiring seamless and stress-free for every organisation. [1]: https://choosemarketers.co.uk/recruitment-agencies-in-west-midlands/
sijef42531
Dining Table Guide: The chair is more than just a piece of furniture. It is the place where families come together, conversations flow naturally, and everyday meals turn into meaningful moments. Whether it’s a quick breakfast or a long weekend dinner.
[Dining Table Guide][1]: The chair is more than just a piece of furniture. It is the place where families come together, conversations flow naturally, and everyday meals turn into meaningful moments. Whether it’s a quick breakfast or a long weekend dinner. [1]: https://mindsetfortrading.com/dining-table-guide-styles-materials-tips-for-modern-homes/
fakharjameel1992
fakharjameel1992 posted this 01 April 2026
Professional SEO tools are essential for analyzing search trends, identifying ranking opportunities, and improving website performance. Many marketers rely on premium platforms for keyword research, backlink analysis, and competitor tracking.
Platforms like Group Buy Seo Tools
provide reliable remote desktop solutions designed specifically for SEO professionals. With stable servers and powerful performance, users can run multiple marketing tools efficiently while maintaining consistent productivity.
These services allow marketers to focus on strategy and optimization instead of dealing with system limitations or performance issues.
Professional SEO tools are essential for analyzing search trends, identifying ranking opportunities, and improving website performance. Many marketers rely on premium platforms for keyword research, backlink analysis, and competitor tracking. Platforms like [**Group Buy Seo Tools**][1] provide reliable remote desktop solutions designed specifically for SEO professionals. With stable servers and powerful performance, users can run multiple marketing tools efficiently while maintaining consistent productivity. These services allow marketers to focus on strategy and optimization instead of dealing with system limitations or performance issues. [1]: https://seordp.net/
naveedxheikh791
naveedxheikh791 posted this 18 July 2026
In this guide, I’m sharing everything I’ve personally tested which features actually deliver, where to safely do a capcut pro apk download, which templates are trending right now, and whether this app can genuinely replace a paid editor. No marketing fluff, just real workflow.
In this guide, I’m sharing everything I’ve personally tested which features actually deliver, where to safely do a [capcut pro apk][1] download, which templates are trending right now, and whether this app can genuinely replace a paid editor. No marketing fluff, just real workflow. [1]: https://capcutproapkdownloads.com/
naveedxheikh791
naveedxheikh791 posted this 19 July 2026
Hundreds of fake websites copy the name and look of Delta Executor. Many distribute APKs with malware to steal Roblox account passwords. ALWAYS download from the official domain. Never trust links from YouTube, random Discord, or Google ads.
Hundreds of fake websites copy the name and look of [Delta Executor][1]. Many distribute APKs with malware to steal Roblox account passwords. ALWAYS download from the official domain. Never trust links from YouTube, random Discord, or Google ads. [1]: https://deltaaexecutors.com/
naveedxheikh791
naveedxheikh791 posted this 27 July 2026
Download vedu apk free for Android and enjoy HD, Full HD & 4K streaming of Bollywood, Hollywood & South Indian films. No login, no subscription, offline downloads & live TV all in one app.
Download [vedu apk][1] free for Android and enjoy HD, Full HD & 4K streaming of Bollywood, Hollywood & South Indian films. No login, no subscription, offline downloads & live TV all in one app. [1]: https://theveduapps.com/
aliansari03285
aliansari03285 posted this 29 August 2026
Learn about Vedu for iOS and how to download or install it on iPhone. Explore availability, installation steps, features, and safe alternatives in 2026.
Learn about [**Vedu for iOS**][1] and how to download or install it on iPhone. Explore availability, installation steps, features, and safe alternatives in 2026. [1]: https://veduappsdl.com/vedu-app-for-ios/
info4662
info4662 posted this 29 August 2026
It sounds like both Themler and Yoast may be outputting the site title, which would explain why it appears twice. I’d first check Yoast’s title template and Themler’s page/header settings before editing header.php, since changing the theme files could make updates harder later.
It sounds like both Themler and Yoast may be outputting the site title, which would explain why it appears twice. I’d first check Yoast’s title [template and Themler’s][1] page/header settings before editing header.php, since changing the theme files could make updates harder later. [1]: http://locksmithyelm.com
