Product tabe magento as menu in responsive design
jurjen
jurjen posted this 02 January 2015
I would like to see the tabs bar roled up like the menu bars for resposive design on the productdetail template.
Support Team posted this 05 January 2015
I'm not sure that I see the idea. Do you mean that in responsive mode you'd like the TAbs control to look like horizontal menu:
Please correct me if I'm wrong.
Hello, I'm not sure that I see the idea. Do you mean that in responsive mode you'd like the TAbs control to look like horizontal menu: !RespView.png! ? Please correct me if I'm wrong. Regards, Aileen
jurjen
jurjen posted this 05 January 2015
Yes, that is what i mean.
Instead of the five tabs, using that symbol would be nice.
Yes, that is what i mean. Instead of the five tabs, using that symbol would be nice.
Jurjen,
Thank you for an interesting proposition.
This feature will be implemented.
Oleg
Jurjen, Thank you for an interesting proposition. This feature will be implemented. Thanks, Oleg
Support Team posted this 09 January 2015
Jurjen,
We researched the tabs bar in responsive and found that usually Accordion/Collapse is used.
In this case user does not need to make scrolling up each time to change tab.
Bootstrap
http://getbootstrap.com/javascript/#collapse
Example of combination Tabs and Collapse (in responsive).
http://tabcollapse.okendoken.com/example/example.html
And we want to try to implement this.
Oleg
Jurjen, We researched the tabs bar in responsive and found that usually Accordion/Collapse is used. In this case user does not need to make scrolling up each time to change tab. Bootstrap http://getbootstrap.com/javascript/#collapse Example of combination Tabs and Collapse (in responsive). http://tabcollapse.okendoken.com/example/example.html And we want to try to implement this. Thanks, Oleg
Support Team posted this 20 February 2015
Accordion feature in responsive is implemented.
