Fixed header and menu
contact27
contact27 posted this 03 January 2015
I would like to create a fixed header in Drupal which contatins the menu, here is an example: http://ausztriaimunkakereso.hu/hu/index.html
I tried several times but it doesn't work properly. How can I do this?
Thank you.
Lajos
Hi, I would like to create a fixed header in Drupal which contatins the menu, here is an example: http://ausztriaimunkakereso.hu/hu/index.html I tried several times but it doesn't work properly. How can I do this? Thank you. Regards, Lajos
Support Team posted this 08 January 2015
Sorry for the delay. What exactly is not working properly?
I've tested "Fix on Screen" option of the Header control and it works just fine.
You can also try the same option with Row control. It works ok too.
Hello Sorry for the delay. What exactly is not working properly? I've tested "Fix on Screen" option of the Header control and it works just fine. You can also try the same option with Row control. It works ok too. Thank you, Olivia
