hello,
in VM templates, I'd like to know how to remove the zoom (magnifier)
on the prodouct image.
Can't find the option.
thank you
d
hello,
thank you
d
no solution?
even via hack, not necessary via themler!
thank you
no solution? even via hack, not necessary via themler! thank youHello Denis,
the zoom is not displayed if product image is output in its full size. You may load not large product image, output it as 100% size and cloud zoom won't be displayed.
Ok, but how I can disable zoom for product with biger image ?
Ok, but how I can disable zoom for product with biger image ?Hi,
There is no such possibility, please use the Aileen's suggestion above.
Hi, i made some trick. It's not right, but it's "works". I made it fast so it's work only partial, but for now, and for me, it's all right :)
You must change CloudZoom.js file, this file generate zoom of product image.
If somebody do something better, pleas share :)
Hi, i made some trick. It's not right, but it's "works". I made it fast so it's work only partial, but for now, and for me, it's all right :) You must change CloudZoom.js file, this file generate zoom of product image. If somebody do something better, pleas share :)Hi, i made some trick. It's not right, but it's "works". I made it fast so it's work only partial, but for now, and for me, it's all right :)
Hi, what do you mean, exactly, with "you must change CloudZoom.js" ??
Change what?
thank you
> Hi, i made some trick. It's not right, but it's "works". I made it fast so it's work only partial, but for now, and for me, it's all right :) > > You must change CloudZoom.js file, this file generate zoom of product image. > > If somebody do something better, pleas share :) Hi, what do you mean, exactly, with "you must change CloudZoom.js" ?? Change what? thank youLast edited 05 May 2016 by denisp
Yes, you must change this file... this is not right way, but so far so good :)
