After reviewing the website you provided, it appears that the blurriness of the product images in the Home page tabs and category listings is likely caused by the way the images are being resized or scaled.
When images are displayed at a size larger or smaller than their original dimensions, the browser may apply resizing algorithms that can result in blurriness or loss of image quality. This is particularly noticeable when images are scaled up.
To improve the image quality in the Home page tabs and category listings, you can try the following steps:
Check the Image Sizes: Verify that the product images used in the Home page tabs and category listings have sufficient resolution and quality. Uploading images with higher resolution can help maintain better image clarity when resizing.
Resize Images Properly: Ensure that the images are resized or scaled down to the appropriate dimensions required by the Home page tabs and category listings. Avoid relying on the browser to resize the images on-the-fly, as this can result in lower quality. Instead, resize the images using image editing software before uploading them to your PrestaShop website.
Optimize Image Compression: Optimize the image compression settings to strike a balance between file size and image quality. Use an image compression tool or plugin to reduce the file size of the images without significantly compromising their visual clarity.
Use Responsive Images: Implement responsive design techniques to serve appropriately sized images based on the device and screen size. This ensures that the images displayed on smaller screens are not unnecessarily large, leading to blurriness or pixelation.
By following these steps, you should be able to improve the image quality and reduce blurriness in the Home page tabs and category listings of your PrestaShop website.
If the issue persists or you need further assistance, I recommend reaching out www.goodliferenovation.com to the support team or developer responsible for the PrestaShop platform or theme you are using. They will have access to the specific configuration and customization options available in your setup and can provide more targeted guidance to address the issue.
If the issue persists or you need further assistance, I recommend reaching out [www.goodliferenovation.com](http://www.goodliferenovation.com) to the support team or developer responsible for the PrestaShop platform or theme you are using. They will have access to the specific configuration and customization options available in your setup and can provide more targeted guidance to address the issue.
