Different headers in Templates
info453
info453 posted this 08 February 2016
I need to create different templates for different pages, I need different headers for differetn pages, but keeping the layout structure. When I remove the header from the page as in your tutorial video it removes the header from all pages.
There is no way of adding the header unless adding it on all the templates.
I also tried adding a layout container instead of the header for a custom page, but I cannot align the layout with the page.
Please help.
Henk
http://uckert.biz
Hi, I need to create different templates for different pages, I need different headers for differetn pages, but keeping the layout structure. When I remove the header from the page as in your tutorial video it removes the header from all pages. There is no way of adding the header unless adding it on all the templates. I also tried adding a layout container instead of the header for a custom page, but I cannot align the layout with the page. Please help. Henk http://uckert.biz
6 Comments
Marco
Marco posted this 08 February 2016
I think you´re talking about a HTML Template.
  1. Dont use "Header" Section in your Template.
  2. Instead create a section for that (but not INSIDE the headerposition) on every page.
    thats all ;)
I think you´re talking about a HTML Template. 1. Dont use "Header" Section in your Template. 2. Instead create a section for that (but not INSIDE the headerposition) on every page. thats all ;)
info453
OK Thanks I will try.
info453
info453 posted this 09 February 2016
I have done that which works, but the only thing is how can I add a search box to the subpages just like the search box on the homepage which user a header.
For your information: I created a section then added a layout container and then the image for custom templates.
Thanks for you answer.
Henk
http://uckert.biz
Hi, I have done that which works, but the only thing is how can I add a search box to the subpages just like the search box on the homepage which user a header. For your information: I created a section then added a layout container and then the image for custom templates. Thanks for you answer. Henk http://uckert.biz
Support Team posted this 10 February 2016
What is the problem with inserting the search box? You can consider adding image as the background image for the section.
Hi, What is the problem with inserting the search box? You can consider adding image as the background image for the section. Sincerely, Hella
info453
info453 posted this 10 February 2016
HI,
Thanks, I put in a section and used the header image as background and then entered columns into the section and then entered the search box into the column.
That works for me now.
Henk
HI, Thanks, I put in a section and used the header image as background and then entered columns into the section and then entered the search box into the column. That works for me now. Regards Henk
