Joomla tag menu style problem
Sem
Sem posted this 10 February 2016
In joomla 3, there are tag item menus, when I am using this function themler template uses some form css style or something like that. It will be correct if for tags menu we can use blog css style. Is there any way to do that within themler? or with simple step in code?
Hello In joomla 3, there are tag item menus, when I am using this function themler template uses some form css style or something like that. It will be correct if for tags menu we can use blog css style. Is there any way to do that within themler? or with simple step in code? Thank you
Support Team posted this 11 February 2016
Sorry, could you please provide a bit more details. Provide a link to the page with the tag menu and explain what style you want to apply.
Hi, Sorry, could you please provide a bit more details. Provide a link to the page with the tag menu and explain what style you want to apply. Sincerely, Hella
