Heading text box won't align within the Sheet Width...
info2163
info2163 posted this 11 February 2016
Whenever I click on a "Heading H4" text box within one of my "Sections", then click on "Length", followed by "Sheet Width", Themler aligns the "Heading H4" text box to the left, as opposed to in the middle, within the width of the sheet. Positioning is set to "Layout".
What am I doing wrong?
Whenever I click on a "Heading H4" text box within one of my "Sections", then click on "Length", followed by "Sheet Width", Themler aligns the "Heading H4" text box to the left, as opposed to in the middle, within the width of the sheet. Positioning is set to "Layout". What am I doing wrong?
info2163
If I click on the misaligned "Heading H4" text box, click "Arrange", then click the "Padding and Margin" icon, and clear the "MARGIN" values (so all boxes are blank) -- I'd previously set the top value to 0px with the "Same Value" switch engaged -- the "Heading H4" text box goes back to the middle.
Why is this?
If I click on the misaligned "Heading H4" text box, click "Arrange", then click the "Padding and Margin" icon, and clear the "MARGIN" values (so all boxes are blank) -- I'd previously set the top value to 0px with the "Same Value" switch engaged -- the "Heading H4" text box goes back to the middle. Why is this?
Support Team posted this 12 February 2016
Sorry, you mean that the 0px margin was set for the heading and it was aligned to the left? The 0px margin makes the control stick to all the edges of the parent container. As I understand, all is fine now?
Hi, Sorry, you mean that the 0px margin was set for the heading and it was aligned to the left? The 0px margin makes the control stick to all the edges of the parent container. As I understand, all is fine now? Sincerely, Hella
info2163
info2163 posted this 12 February 2016
Hi Hella,
Thank you for your reply.
The Margin was set to 0px in all four fields, as the "Same Value" switch was engaged, and this seemed to cause the Heading H4 text box to align itself to the extreme left of my page. As soon as I cleared the values, the Heading H4 box aligned itself to the middle, which is where I wanted it to be.
However, if I go back into the MARGIN dialogue, and click in the top Margin field (the only one not greyed out), I notice the slider is in the position of what appears to be 0px, yet the fields are blank, and if I type 0px into that field, my Header H4 text box becomes misaligned again. This isn't a problem for me, so long as I leave the fields blank, but what I would like to know is, when you clear the values, what is the value not being displayed, if the slider is in the 0px position? Just intrigued.
Also, I seem to be experiencing the same misalignment issues with another Header H4 text box, and clearing the MARGIN values does not work for this one. I have checked other values, and cleared those, yet it remains where it is. So I must be missing something somewhere, or doing something wrong...
Any way of finding out what's causing this issue?
Hi Hella, Thank you for your reply. The Margin was set to 0px in all four fields, as the "Same Value" switch was engaged, and this seemed to cause the Heading H4 text box to align itself to the extreme left of my page. As soon as I cleared the values, the Heading H4 box aligned itself to the middle, which is where I wanted it to be. However, if I go back into the MARGIN dialogue, and click in the top Margin field (the only one not greyed out), I notice the slider is in the position of what appears to be 0px, yet the fields are blank, and if I type 0px into that field, my Header H4 text box becomes misaligned again. This isn't a problem for me, so long as I leave the fields blank, but what I would like to know is, when you clear the values, what is the value *not* being displayed, if the slider is in the 0px position? Just intrigued. Also, I seem to be experiencing the same misalignment issues with another Header H4 text box, and clearing the MARGIN values does not work for this one. I have checked other values, and cleared those, yet it remains where it is. So I must be missing something somewhere, or doing something wrong... Any way of finding out what's causing this issue?
Support Team posted this 17 February 2016
there have been some issues with aligning controls which should be resolved in the latest Themler update.
Please open the theme in Themler and update it.
In case the issue persists please attach the theme here and note what exact control is not aligned properly.
Hello, there have been some issues with aligning controls which should be resolved in the latest Themler update. Please open the theme in Themler and update it. In case the issue persists please attach the theme here and note what exact control is not aligned properly. regards, Aileen
