posted this
12 January 2015
Currently there is an issue with Horizontal Menu and Top Menu controls. If there is no menu block assigned to the appropriate region the container for the menu controls will not be outputted in page structure. As the result it's not visible in Outline (Top nav bar in Themler >> Controls >> Outline). The Horizontal Menu and Top Menu controls work in a different way than VerticalMenu Region or Drupal Region controls which should be displayed in Outline.
I've discussed this issue with our developers and we found a possible solution. We'll work on it. In the meantime to see the menus in Outline you should add a menu block to the appropriate region. You can do it for preview theme only. In this case the menus will appear in Themler only, not on the front end.
