I would like to know if i can remove the zoom from products images.
is there any way to open the image in real size when clicking the image?
Unfortunately there is no such possibility now, we are using our own CloudZoom code. The option to disable it is in our wish list.
Where can I find the code of the zoom? And if I will disabled it, will it work link the default wordpress layout?
Thank you.
There is a CloudZoom.js file within the theme folder. You can try to delete it, but note that we haven't tried to perform such modifications and can not guarantee the result.
Unfortunately this feature is not included in the upcoming updates. Please vote for it.
Only 3 votes in this topic. I'll change it to the wishlist type, maybe more users will notice it.
If you rename CloudZoom.js (file within the theme folder) you can disable this option.
Hi, If you rename CloudZoom.js (file within the theme folder) you can disable this option.There's a lot of topics on this on your forums whether you see votes or not. Do the search. I found them and voted on everyone. Seems you would be tired of answering the same topic.
There's a lot of topics on this on your forums whether you see votes or not. Do the search. I found them and voted on everyone. Seems you would be tired of answering the same topic.Last edited 17 April 2018 by LGWeb
We consider these suggestions, but we do not have this option in our plans for now.
