Have a question that the names of the buttons that I change it? I'm using PrestaShop 1.6
Have a question that the names of the buttons that I change it? I'm using PrestaShop 1.6Last edited 13 January 2015 by peterkovacssoft
Hi Kovács,
I'm not sure I fully understand your issue.
You just want to change the button name?
Ivan
in vain I go to the site and there I select in the translation of the front office and the subject does not edit the text "cart (empty)" to another, and I do not understand why you do the same for the "new" to "check out", "add to cart",
and yet it would be a problem when the goods will not be passed over Dobb anything
Thank you, It's clear now.
We're aware about a number of issue with localization. Our developers are working on them.
Unfortunately I can't tell you when they will be solved.
nem tudom hogy segít a megoldásban de miután kivettem a szűrő modult utána mindent normálisan mutatot , a másik probléma pedig az lenne hogy ha a részletekre megyek re egy terméknél nem mutatja az árat pl(termék 1190 Forint részletekben ezt látom termék : 0.00)
nem tudom hogy segít a megoldásban de miután kivettem a szűrő modult utána mindent normálisan mutatot , a másik probléma pedig az lenne hogy ha a részletekre megyek re egy terméknél nem mutatja az árat pl(termék 1190 Forint részletekben ezt látom termék : 0.00)Hello
Unfortunately the online translation of your message is difficult to understand.
Could you please explain it in more details?
What exactly filter you're referring to?
The other issue with product details is not quite cleat too.
First image(nevtelen.png) shows the price of the product
2 (nevtelen2.png)does not show the price of the product
Layered navigation block when I take the blame aa poziciókból or disable this module you can display all the products are good but once again switches back immediately and stay ahead of all the products do not show again
First image(nevtelen.png) shows the price of the product 2 (nevtelen2.png)does not show the price of the product Layered navigation block when I take the blame aa poziciókból or disable this module you can display all the products are good but once again switches back immediately and stay ahead of all the products do not show againLast edited 16 January 2015 by peterkovacssoft
I do not know what you did but improved the above error illustrated by pictures :)
I do not know what you did but improved the above error illustrated by pictures :)Hi Peter,
I'm not sure that I understand your response properly. Do you mean that if Wholesale price option is set to 0 and if you add a variation at Combinations tab, then if this variation is selected the price is 0.
Right?
Please correct me if I'm wrong.
a price of one good apology has remained the same 0 Ft(combination if I order you to disappear price)
a price of one good apology has remained the same 0 Ft(combination if I order you to disappear price)Last edited 16 January 2015 by peterkovacssoft
Thanks for the explanation, we are aware of this issue. We'll let you know as soon as it is fixed.
Themes\my_thema\includes\cart_view_1.tpl
Here, if I change the things you can change the name of the shopping cart button
Hello Peter,
just to let you know. The reported issue related to product variations and price has been resolved in the recent Themler update.
