posted this
29 February 2016
Hello Tom,
regarding adding widget inside Section and Column: please refer to this forum post http://answers.themler.com/questions/60290/wordpress-section-panel-adding-2-latest-blogs
is it possible to have a wide slider at the top the stretches the total width, then have a section (or something) below it where I have 2 objects.. text at the left, and a WP widget at the right?
It is possible if:
1).you enable Content and Sidebars under Layout;
2).enable Right Sidebar;
3).then add Section with Slider right above the Content;
4).insert Section (with something) inside Content;
5).locate WP widget in the Widget Area which is added to Right Sidebar
Hello Tom,
It is possible if:
