posted this
26 February 2016
We described Blog template and how it works in this article:
http://answers.themler.com/articles/36343/how-to-work-with-templates-in-joomla-themes
Simply open Blog Template block.
In short, if all fields are empty:
The default Joomla settings will be used.
If at least one field (for any responsive mode) is not empty the Themler blog layout will be used.
The only thing that Themler layout will show Leading articles according to the joomla settings because there is no appropriate option in Themler.
Simply keep all fields empty if you want to use Joomla blog layout. But please note that Themler theme doe snot provide additional stylesheet for joomla blog layout. In some cases it's not good for responsive.
In short, if **all** fields are empty:
!posts-columns-j.png!
