Themla and structured data - schema.org
bruce3
bruce3 posted this 18 February 2016
HI,
In the functions.php there is reference to:
function theme_wc_get_product_schema() {
if (function_exists('woocommerce_get_product_schema'))
return woocommerce_get_product_schema();
return 'http://schema.org/Product';
Problem is that the schema does not reference the product name correctly. When checking on google the following appears:
Name is missing and required.
Product: http://tdfstudio.co.za/products/decor/abstract-floral-1200-x-1200/product-267
image: http://tdfstudio.co.za/wp-content/uploads/2015/12/AS029-1200x1200mm.jpg
sku: AS029
name: missing and required
Is this a Themler issue?
There are no other structured data plugins installed.
Bruce
HI, In the functions.php there is reference to: function theme_wc_get_product_schema() { if (function_exists('woocommerce_get_product_schema')) return woocommerce_get_product_schema(); return 'http://schema.org/Product'; } Problem is that the schema does not reference the product name correctly. When checking on google the following appears: Name is missing and required. Product: http://tdfstudio.co.za/products/decor/abstract-floral-1200-x-1200/product-267 image: http://tdfstudio.co.za/wp-content/uploads/2015/12/AS029-1200x1200mm.jpg sku: AS029 name: missing and required Is this a Themler issue? There are no other structured data plugins installed. Regards, Bruce
11 Comments
Support Team posted this 24 February 2016
Hello Bruce,
we'll check it and will let you know the results.
Hello Bruce, we'll check it and will let you know the results. Regards, Aileen
Support Team posted this 26 February 2016
Hello Bruce,
the provided links point to non existing products, may be this is the reason?
What site you have checked? Please provide link to it,
Please confirm that you have used this tool
https://developers.google.com/webmasters/structured-data/testing-tool/
If you activate one of WP default theme and check the site again do you get the same results as with Themler theme?
Hello Bruce, the provided links point to non existing products, may be this is the reason? What site you have checked? Please provide link to it, Please confirm that you have used this tool https://developers.google.com/webmasters/structured-data/testing-tool/ If you activate one of WP default theme and check the site again do you get the same results as with Themler theme? regards, Aileen
bruce3
bruce3 posted this 26 February 2016
i have checked.
I get the same results on this website.
Product:    http://www.aage.co.za/gym-equipment/gym-accessories/weight-plates-standard/1-25kg-standard-tri-grip-rubber-coated-weight-plate/product-2451
image: http://www.aage.co.za/wp-content/uploads/2014/10/Tri-Grip-Rubber-Coated-Standard-Weight-Plate-125kg.jpg
sku: AA0025
The results for the above confirmed in google Webmaster Tools. 464 Error pages (add aage.co.za in front of the links below):
/gym-equipment/commercial-products/nautilus/nautilus-airfit-ub/
1
1
2/24/16
Missing: name
/gym-equipment/strength-equipment/invincible-strength/inv-lower-back/
1
1
2/22/16
Missing: name
/gym-equipment/strength-equipment/invincible-strength/inv-dumbbell-rack-vertical-6-sets/
1
1
2/22/16
Missing: name
/gym-equipment/strength-equipment/invincible-strength/inv-bench-incline-benchpress-and-stands/
1
1
2/22/16
Missing: name
/gym-equipment/strength-equipment/a6-strength/a6-dual-adjustable-pulley/
1
1
2/22/16
Missing: name
/gym-equipment/strength-equipment/a6-strength/a6-utility-bench/
1
1
2/22/16
Missing: name
/gym-equipment/strength-equipment/star-trac/instinct-strength/instinct-strength-dumbbell-rack-10-pair-2-tier/
1
1
2/21/16
Missing: name
/gym-equipment/commercial-products/star-trac-cardio/indoor-cycle-studio-bikes/star-trac-studio-3-indoor-cycle/
1
1
2/19/16
Missing: name
/gym-equipment/strength-equipment/invincible-strength/inv-dumbbell-rack-triple-1-5m10-sets/
1
1
2/19/16
Missing: name
/gym-equipment/strength-equipment/star-trac/instinct-strength/instinct-strength-rotary-torso/
1
1
2/18/16
Missing: name
/gym-equipment/strength-equipment/invincible-strength/inv-leg-press-50-degree-olympic/
1
1
2/18/16
Missing: name
Another Themler site:
Product:    http://tdfstudio.co.za/products/decor/decor-mirror/black-and-brown/o8f-221-394959-shiny-black-set-3-round/product-2480
image: http://tdfstudio.co.za/wp-content/uploads/2015/12/TS033.jpg
sku: TS033
Two sites and the same results using the Google test tool. Not to mention the structured data errors.
Bruce
Hi i have checked. I get the same results on this website. Product: http://www.aage.co.za/gym-equipment/gym-accessories/weight-plates-standard/1-25kg-standard-tri-grip-rubber-coated-weight-plate/product-2451 image: http://www.aage.co.za/wp-content/uploads/2014/10/Tri-Grip-Rubber-Coated-Standard-Weight-Plate-125kg.jpg sku: AA0025 name: missing and required The results for the above confirmed in google Webmaster Tools. 464 Error pages (add aage.co.za in front of the links below): /gym-equipment/commercial-products/nautilus/nautilus-airfit-ub/ 1 1 2/24/16 – – – – Missing: name /gym-equipment/strength-equipment/invincible-strength/inv-lower-back/ 1 1 2/22/16 – – – – Missing: name /gym-equipment/strength-equipment/invincible-strength/inv-dumbbell-rack-vertical-6-sets/ 1 1 2/22/16 – – – – Missing: name /gym-equipment/strength-equipment/invincible-strength/inv-bench-incline-benchpress-and-stands/ 1 1 2/22/16 – – – – Missing: name /gym-equipment/strength-equipment/a6-strength/a6-dual-adjustable-pulley/ 1 1 2/22/16 – – – – Missing: name /gym-equipment/strength-equipment/a6-strength/a6-utility-bench/ 1 1 2/22/16 – – – – Missing: name /gym-equipment/strength-equipment/star-trac/instinct-strength/instinct-strength-dumbbell-rack-10-pair-2-tier/ 1 1 2/21/16 – – – – Missing: name /gym-equipment/commercial-products/star-trac-cardio/indoor-cycle-studio-bikes/star-trac-studio-3-indoor-cycle/ 1 1 2/19/16 – – – – Missing: name /gym-equipment/strength-equipment/invincible-strength/inv-dumbbell-rack-triple-1-5m10-sets/ 1 1 2/19/16 – – – – Missing: name /gym-equipment/strength-equipment/star-trac/instinct-strength/instinct-strength-rotary-torso/ 1 1 2/18/16 – – – – Missing: name /gym-equipment/strength-equipment/invincible-strength/inv-leg-press-50-degree-olympic/ 1 1 2/18/16 – – – – Missing: name Another Themler site: Product: http://tdfstudio.co.za/products/decor/decor-mirror/black-and-brown/o8f-221-394959-shiny-black-set-3-round/product-2480 image: http://tdfstudio.co.za/wp-content/uploads/2015/12/TS033.jpg sku: TS033 name: missing and required Two sites and the same results using the Google test tool. Not to mention the structured data errors. Regards, Bruce
bruce3
This site created in themler, same result:
Product:    http://www.discreetsecrets.com.au/product/pink-animal-print-leopard-latex-waist-trainer-body-shaper/product-913
image: http://www.discreetsecrets.com.au/wp-content/uploads/2015/09/2015081117543164471049.jpg
sku: N/A
Same here:
Product:    http://classicalkatresz.hu/termek/proba-termek-1/product-13
image: http://classicalkatresz.hu/wp-content/uploads/2015/12/afis_eveniment_final.jpg
These are not sites I have created, the results are the same though.
Bruce
Hi This site created in themler, same result: Product: http://www.discreetsecrets.com.au/product/pink-animal-print-leopard-latex-waist-trainer-body-shaper/product-913 image: http://www.discreetsecrets.com.au/wp-content/uploads/2015/09/2015081117543164471049.jpg sku: N/A name: missing and required Same here: Product: http://classicalkatresz.hu/termek/proba-termek-1/product-13 image: http://classicalkatresz.hu/wp-content/uploads/2015/12/afis_eveniment_final.jpg name: missing and required These are not sites I have created, the results are the same though. Regards, Bruce
Support Team posted this 01 March 2016
Hello Bruce,
thank you for details.
We're looking into this issue and will contact you then.
Hello Bruce, thank you for details. We're looking into this issue and will contact you then. regards, Aileen
Support Team posted this 09 March 2016
Hello Bruce,
number of changes will be included into Themler theme in one of the next updates, so the themes will be validated without reported errors.
Hello Bruce, number of changes will be included into Themler theme in one of the next updates, so the themes will be validated without reported errors. regards, Aileen
bruce3
bruce3 posted this 09 March 2016
Hi Aileen,
Thank you for the update.
Bruce
Hi Aileen, Thank you for the update. Regards, Bruce
oceanite
oceanite posted this 30 January 2017
I have the same problem.
Has not been solved yet ?
Hello, I have the same problem. Has not been solved yet ? Thanks Regards
Support Team posted this 31 January 2017
Hello Jesus,
unfortunately this issue was put on hold and no solution was found.
I'd recommend that you create a new private topic, describe the problem and provide access to your CMS admin back end. We'll investigate the problem.
Hello Jesus, unfortunately this issue was put on hold and no solution was found. I'd recommend that you create a new private topic, describe the problem and provide access to your CMS admin back end. We'll investigate the problem. regards, Aileen
oceanite
oceanite posted this 03 February 2017
Hello Aileen,
it works perfectly. It was my fault. I had changed a template
Hello Aileen, it works perfectly. It was my fault. I had changed a template Thanks
Support Team posted this 07 February 2017
Hello Jesus,
you're welcome!
Let us know if you have additional questions
Hello Jesus, you're welcome! Let us know if you have additional questions regards, Aileen
