Themler Slider isn't responsive
TSMM
TSMM posted this 15 January 2015
On a Wordpress Themler theme the sliders are not correctly responsive. Is there a way to set the images in the slider to be responsive?
18 Comments
Support Team posted this 15 January 2015
Tracy,
Slider is responsive, but controls positioning in Slider is absolute.
There is no automatic way to recalculate position for each mode.
By default Themler places elements proportionally to the responsive mode size.
To adjust positions for each responsive mode please switch the mode and move elements to positions you want. Additionally you can change size or font size for each responsive mode.
Please let us know if you sill have any questions.
Oleg
Tracy, Slider is responsive, but controls positioning in Slider is absolute. There is no automatic way to recalculate position for each mode. By default Themler places elements proportionally to the responsive mode size. To adjust positions for each responsive mode please switch the mode and move elements to positions you want. Additionally you can change size or font size for each responsive mode. Please let us know if you sill have any questions. Thanks, Oleg
TSMM
Sorry, I don't understand. What is "controls positioning" in slide is absolute - mean???
Tracy,
Please switch responsive mode and adjust image or text position when it is needed.
We are working on automating responsive positioning.
Oleg
Tracy, Please switch responsive mode and adjust image or text position when it is needed. We are working on automating responsive positioning. Thanks, Oleg !Responsive.png!
TSMM
I can't see how to resize the image that is inside the slider. Or do I have to create new images separately and replace the images there with smaller one?
OK, I thought that you ask how to move text in responsive modes.
If you need to move Text please do following:
1. Switch to one of responsive modes
2. Move text into correct position
OK, I thought that you ask how to move text in responsive modes. If you need to move **Text** please do following: 1. Switch to one of responsive modes 2. Move text into correct position !responsive3.png!
If you want to make Slide background image responsive please go to Image options.
And experiment with Size and Position properties.
For example Contain Size will not crop image in all responsive modes.
If you want to make Slide background image responsive please go to Image options. And experiment with Size and Position properties. For example **Contain** Size will not crop image in all responsive modes. !image-options.png!
See samples of using Size and Position properties:
See samples of using **Size** and **Position** properties: !image-size.png!
TSMM
TSMM posted this 17 January 2015
Great instructions, thank you. I wish there was somewhere all this was in one place and had videos explaining it. Themler will be very powerful, if people can actually use it correctly.
Question: Can we hyperlink each slide to a different page on our website?
Great instructions, thank you. I wish there was somewhere all this was in one place and had videos explaining it. Themler will be very powerful, if people can actually use it correctly. Question: Can we hyperlink each slide to a different page on our website?
Support Team posted this 19 January 2015
Tracy,
We will try to add Slide ULR functionality.
You may try the following workaround.
1. Add HTML Control inside each slide, in its HTML property add code like:
<a style="height:100%; width:100%;display:block" href="http://your-url"></a>
2. Change HTML control properties:
Oleg
Tracy, We will try to add Slide ULR functionality. You may try the following workaround. 1. Add **HTML** Control inside each slide, in its HTML property add code like: <a style="height:100%; width:100%;display:block" href="http://your-url"></a> 2. Change **HTML** control properties: !slide-url.png! Thanks, Oleg
Tracy,
We plan to add Slider URL property with one of the next updates.
Oleg
Tracy, We plan to add Slider URL property with one of the next updates. Thanks, Oleg !slider-url.png!
TSMM
TSMM posted this 21 January 2015
Very good. Thanks.
Can you tell me how to edit the HTML on a slide image?
Very good. Thanks. Can you tell me how to edit the HTML on a slide image?
Support Team posted this 21 January 2015
Hi Tracy,
the Image control located on the slide or slider background image does not have "HTML" option which could be edited.
But if you added HTML control (via Insert >> Other >> HTML) then it has the HTML property where you may add custom HTML
Hi Tracy, the Image control located on the slide or slider background image does not have "HTML" option which could be edited. But if you added HTML control (via Insert >> Other >> HTML) then it has the HTML property where you may add custom HTML !HTMLControl.png! regards, Aileen
Support Team posted this 23 January 2015
The new update supports slider URL feature.
Also improved Slider responsive modes.
Oleg
The new update supports slider URL feature. Also improved Slider responsive modes. Thanks, Oleg
TSMM
TSMM posted this 24 January 2015
Brilliant, thanks.
Brilliant, thanks.
Mauricio Huayta
Mauricio Huayta posted this 29 August 2015
I would make my embedded videos from youtube are responsive could help me with this please ?. Cheers
Support Team posted this 01 September 2015
I've answered your question here.
Hi, > I would make my embedded videos from youtube are responsive could help me with this please ? I've answered your question [here][1]. Thank you, Olivia [1]: http://answers.themler.com/questions/24041/i-would-make-my-embedded-videos-from-youtube-are-responsive-could-help-me-with-this-please-cheers
Box2424
Box2424 posted this 22 February 2016
^^^^ THIS IS THE CORRECT ANSWER ^^^^^
> See samples of using **Size** and **Position** properties: > ![](http://attachments.answers.billiondigital.com/341/1341/image-size.png) ^^^^ **THIS IS THE CORRECT ANSWER** ^^^^^
DaveOzric
DaveOzric posted this 19 October 2016
I have added a topic, so please vote on a solution.
http://answers.themler.com/questions/104260/responsive-images-on-slider-please-vote
I have added a topic, so please vote on a solution. http://answers.themler.com/questions/104260/responsive-images-on-slider-please-vote
