Themler - insert a secondary nav menu bar above main menu bar
TSMM
TSMM posted this 15 January 2015
How do I add a secondary navigation bar that will contact a custom WP Menu into an area along the top of the page above the main menu?
Support Team posted this 15 January 2015
Hello Tracy,
you may add second Horizontal Menu to your theme.
1. Add Horizontal Menu control and locate it where you want on the page. In your case you probably add Row with Columns control above the Header and then use Insert >> Navigation >> Horizontal Menu to add menu inside a column.
2. Note, that at this step you'll get two identical menus.
3. Apply theme to CSM and then open WP administration back end.
4. Open Appearance >> Menus and create new menu. Add necessary links to it. Under Menu Settings section select one of the "Primary Navigation" menu options:
5.Just in case open the menu that was used as Primary Navigation menu in WP and make sure that one of 'Primary Navigation' options is enabled for it.
6.Return to Themler and refresh content. You should see two different horizontal menus. E.g.:
Hello Tracy, you may add second Horizontal Menu to your theme. 1. Add Horizontal Menu control and locate it where you want on the page. In your case you probably add Row with Columns control above the Header and then use Insert >> Navigation >> Horizontal Menu to add menu inside a column. 2. Note, that at this step you'll get two identical menus. 3. Apply theme to CSM and then open WP administration back end. 4. Open Appearance >> Menus and create new menu. Add necessary links to it. Under Menu Settings section select one of the "Primary Navigation" menu options: !SecondMenuSource.png! 5.Just in case open the menu that was used as Primary Navigation menu in WP and make sure that one of 'Primary Navigation' options is enabled for it. 6.Return to Themler and refresh content. You should see two different horizontal menus. E.g.: !SecondMenuResult.png! Regards, Aileen
TSMM
Wow, thank you, these instructions were awesome, really appreciate your help with this.
TSMM
TSMM posted this 17 January 2015
Do I have to do all these steps again for all the different page layouts? Is there an easy way to "Apply this to all layouts?"
TSMM
How do I know what Navigation Menu number is the one I just created? so when I go to Menus I know which box to tick?
Support Team posted this 17 January 2015
The next update will have Header and Footer areas that automatically share controls between Templates.
For now please use Paste and Share feature.
In the current version you can copy Menu on one template and paste and share on another template.
Paste and Share command is available in right-click menu and in the top Toolbar.
The next update will have [Header](http://answers.billiondigital.com/articles/4466) and [Footer](http://answers.billiondigital.com/articles/4463) areas that automatically share controls between Templates. !headersharing.png! For now please use **Paste and Share** feature. In the current version you can copy **Menu** on one template and paste and share on another template. **Paste and Share** command is available in right-click menu and in the top Toolbar. !paste-and-share.png!
