Themler - How do I make the text in the nav bar align BOTTOM instead of Center?
TSMM
TSMM posted this 15 January 2015
I want to have the text on the buttons on the main nav bar to align bottom on the menu tabs instead of center - how can I do that?
Support Team posted this 15 January 2015
Hi Tracy,
please try the following solution:
1. change the padding of Horizontal Menu >> Item
and set it to use 20px for right and left padding and 0px for top and bottom;
2.reduce the menu height by dragging the border as displayed on screenshot
3.select Horizontal Menu control and drag it to the bottom of header
Hi Tracy, please try the following solution: 1. change the padding of Horizontal Menu >> Item !HMenuItemPadding.png! and set it to use 20px for right and left padding and 0px for top and bottom; 2.reduce the menu height by dragging the border as displayed on screenshot !menuHeight.png! 3.select Horizontal Menu control and drag it to the bottom of header !relocateMenu1.png! Regards, Aileen
TSMM
TSMM posted this 17 January 2015
Sorry, I want to leave the nav menu buttons where they are, just make the text on the nav buttons align to the bottom of the menu button.
Support Team posted this 17 January 2015
Setting the bottom padding value for the menu item to 0 makes the text stick to the bottom of the item. If that does not work for you, please provide a link to your theme.
Hi, Setting the bottom padding value for the menu item to 0 makes the text stick to the bottom of the item. If that does not work for you, please provide a link to your theme. Sincerely, Hella BillionDigital Team
