Wordpress themes bug when " tax-inclusive pricing " is activated
pciberica
pciberica posted this 25 February 2016
When you export a Wordpress theme there is a fault with WooCommerce .
In WooCommerce settings , with the option to "show prices with taxes " does not work. In the store shows the price without tax.
When you export a Wordpress theme there is a fault with WooCommerce . In WooCommerce settings , with the option to "show prices with taxes " does not work. In the store shows the price without tax.
6 Comments
Support Team posted this 01 March 2016
We are investigating your issue.
Thank you!
Hi, We are investigating your issue. Thank you!
thomas1_oliver6
thomas1_oliver6 posted this 09 May 2026
This looks like a common WooCommerce issue where tax display settings don’t sync properly with theme export configurations. Often it happens when theme files override default pricing behavior or caching interferes with tax rules.
A helpful reference for checking related data is property tax records which can help understand how tax values are structured in public systems. Double-checking WooCommerce tax settings along with theme functions usually resolves this inconsistency.
This looks like a common WooCommerce issue where tax display settings don’t sync properly with theme export configurations. Often it happens when theme files override default pricing behavior or caching interferes with tax rules. A helpful reference for checking related data is [property tax records][1] which can help understand how tax values are structured in public systems. Double-checking WooCommerce tax settings along with theme functions usually resolves this inconsistency. [1]: https://muskingum-county-auditors.org/property-tax-records
noah1_liam6
noah1_liam6 posted this 10 May 2026
Interesting issue with WooCommerce tax-inclusive pricing; it often comes from theme overrides conflicting with core tax display settings. You might want to check template files and ensure no custom pricing hooks are forcing tax exclusion.
For general reference on land and assessment data, Property records search can be useful.Hopefully updating the tax display priority in settings resolves the mismatch.
Interesting issue with WooCommerce tax-inclusive pricing; it often comes from theme overrides conflicting with core tax display settings. You might want to check template files and ensure no custom pricing hooks are forcing tax exclusion. For general reference on land and assessment data, [Property records search][1] can be useful.Hopefully updating the tax display priority in settings resolves the mismatch. [1]: https://pimacountypropertyappraiser.org/tax-estimator
Ivan1_micah6
Ivan1_micah6 posted this 10 May 2026
I ran into something similar a while back when configuring WooCommerce pricing settings, and the issue turned out to be related to how the theme handled tax display hooks. It’s surprising how often tax-inclusive pricing breaks after exporting or migrating themes. While troubleshooting, I checked some useful resources related to Property tax information and noticed how important accurate value calculations and display logic can be across different systems. Hopefully the developer can patch the compatibility issue in the next update because it definitely affects user trust during checkout.
I ran into something similar a while back when configuring WooCommerce pricing settings, and the issue turned out to be related to how the theme handled tax display hooks. It’s surprising how often tax-inclusive pricing breaks after exporting or migrating themes. While troubleshooting, I checked some useful resources related to [Property tax information](https://gwinnettcountypropertyappraiser.org) and noticed how important accurate value calculations and display logic can be across different systems. Hopefully the developer can patch the compatibility issue in the next update because it definitely affects user trust during checkout.
jameswalterra8262
jameswalterra8262 posted this 27 May 2026
I am closely tracking this frustrating WordPress themes bug when tax-inclusive pricing is activated because e-commerce calculations must be flawless, an accuracy requirement that is just as critical as maintaining strict compliance protocols within corporate financial data management systems.
I am closely tracking this frustrating WordPress themes bug when tax-inclusive pricing is activated because e-commerce calculations must be flawless, an accuracy requirement that is just as critical as maintaining strict compliance protocols within corporate [financial data management][1] systems. [1]: https://financedataai.com/efficient-data-management/
kibepa1109
kibepa1109 posted this 24 June 2026
This Wordpress theme's bug when " tax-inclusive pricing " is activated is so informative that we can learn here and use it when we need to. So pole barn kits Batesville MS is bringing the best solution to us so we can get our results.
This Wordpress theme's bug when " tax-inclusive pricing " is activated is so informative that we can learn here and use it when we need to. So [pole barn kits Batesville MS][1] is bringing the best solution to us so we can get our results. [1]: https://mississippipolebarnbuilders.com/pole-barn-kits/
