Part of the user interface gets lost
rob278
rob278 posted this 28 February 2016
I want to use a flash generated animation in a Joomla website. I've created a template with Themler and added the necessary Java scripts in the head by editing the template manualy (it would be nice to have this functionality within themler). So far so good.
I use the Insert HTML link in themler to put the actual java animation in the Joomla page ( the code for that is something like this: <canvas id width height style></canvas>).
For the animation to start on loading the page I only have to put an onload="init();" statement in the body tag. If I do so it works, but when i want to edit the template again in themler all links in the INSERT part of the user interface are gone. When I remove the onload="init();" statement from the body tag the controls are bach again.
I want to use a flash generated animation in a Joomla website. I've created a template with Themler and added the necessary Java scripts in the head by editing the template manualy (it would be nice to have this functionality within themler). So far so good. I use the Insert HTML link in themler to put the actual java animation in the Joomla page ( the code for that is something like this: &lt;canvas id width height style&gt;&lt;/canvas&gt;). For the animation to start on loading the page I only have to put an onload="init();" statement in the body tag. If I do so it works, but when i want to edit the template again in themler all links in the INSERT part of the user interface are gone. When I remove the onload="init();" statement from the body tag the controls are bach again.
8 Comments
Support Team posted this 01 March 2016
We are investigation this issue.
Thank you!
Hi, We are investigation this issue. Thank you!
Please add Java scripts in the head using Additional Head Html
Please add Java scripts in the head using Additional Head Html !addhead.png!
rob278
rob278 posted this 02 March 2016
That is a nice option for adding javascript to the head of my page. I didn't know it was there. It only does not solve my onload="init();" problem, for that has to be in the body tag.
Support Team posted this 02 March 2016
Create custom javascript file ( name example - slider_init.js) with code:
window.onload = init();
And include this file after necessary Java scripts in the head using Additional Head Html.
Create custom javascript file ( name example - slider_init.js) with code: window.onload = init(); And include this file after necessary Java scripts in the head using Additional Head Html.
rob278
rob278 posted this 07 March 2016
I'm not Java Expert but loading the script with the code "window.onload = init();" is not starting the java animation. Adding the code "onload="init();""to the body tag does start the animation but gives problems with the Themler scripts.
Hi, I'm not Java Expert but loading the script with the code "window.onload = init();" is not starting the java animation. Adding the code "onload="init();""to the body tag does start the animation but gives problems with the Themler scripts.
rob278
The java code that does the trick is:
function init() {
    // some code to present a Java animation
window.onload = init;
If this is used the Themler scripts are not affected.
The java code that does the trick is: function init() { // some code to present a Java animation } window.onload = init; If this is used the Themler scripts are not affected.
Support Team posted this 07 March 2016
Hello Rob,
I'm passing your question to our developers. We'll contact you when solution is available.
Hello Rob, I'm passing your question to our developers. We'll contact you when solution is available. Regards, Aileen
Support Team posted this 09 March 2016
Please provide an access to the site.
