2 Video or Documentation Requests
Dave
Dave posted this 02 March 2016
Is it possible for Themler to produce just 2 through and complete "walk throughs?"
I would like slow videos showing how to do the following:
  • How to remove the "made by Themler" footer credit in a theme and
    replace it with "ABC"
  • How to make a navigation menu such that it appears on all site pages
I know there is not much documentation on using Themler for whatever reason, but I think these two would be very helpful if anyone would please care to provide these.
Is it possible for Themler to produce just 2 through and complete "walk throughs?" I would like slow videos showing how to do the following: - How to remove the "made by Themler" footer credit in a theme and replace it with "ABC" - How to make a navigation menu such that it appears on all site pages I know there is not much documentation on using Themler for whatever reason, but I think these two would be very helpful if anyone would please care to provide these.
Support Team posted this 03 March 2016
Thanks for your request, but for now I can give you recommendations on how to do the above mentioned operations:
1. Made by Themler backward links can be easily removed just by deleting the Backward Links control, click on the links in the footer, the control will be highlighted and just press del.
2. In the default template menu is initially positioned within the Header container that is shared between all the templates so it should appear on all the pages. In this case tutorials won't help as might be you have removed it somewhere or positioned the menu outside the Header and such situations should be held individually.
Hi, Thanks for your request, but for now I can give you recommendations on how to do the above mentioned operations: 1. Made by Themler backward links can be easily removed just by deleting the Backward Links control, click on the links in the footer, the control will be highlighted and just press del. 2. In the default template menu is initially positioned within the Header container that is shared between all the templates so it should appear on all the pages. In this case tutorials won't help as might be you have removed it somewhere or positioned the menu outside the Header and such situations should be held individually. Sincerely, Hella
