section layout and pages.
Giuma
Giuma posted this 03 March 2016
After login in my area i download some sections pages... by "free html download" button
but if i try to import zip files by function "load from zip", dont' works and i have error: Unable to apply presets. Wrong file format or it's corrupted
if i open themler and i add ideas sections from online site is all ok,
After login in my area i download some sections pages... by "free html download" button but if i try to import zip files by function "load from zip", dont' works and i have error: Unable to apply presets. Wrong file format or it's corrupted if i open themler and i add ideas sections from online site is all ok,
Support Team posted this 04 March 2016
Hello Giuseppe,
that's behavior by design.
The Sections could be downloaded from templates.themler.com as ZIP file as HTML download.
If you want to use Section in your theme then insert Section from templates.themler.com directly in Themler.
Hello Giuseppe, that's behavior by design. The Sections could be downloaded from templates.themler.com as ZIP file as HTML download. If you want to use Section in your theme then insert Section from templates.themler.com directly in Themler. regards, Aileen
Giuma
Giuma posted this 04 March 2016
ok, but but then what is the "load from zip "
Support Team posted this 05 March 2016
The "free html download" option in BillionThemes exports Sections as plain HTML.
The "load from zip" is the option loads Exported sections (section packadge with json, etc):
For example, you created a Section from scratch. You can export it and them import into another theme.
Hi, The "free html download" option in BillionThemes exports Sections as plain HTML. The "load from zip" is the option loads Exported sections (section packadge with json, etc): !export-section.png! For example, you created a Section from scratch. You can export it and them import into another theme. Thank you, Olivia
Giuma
Giuma posted this 06 March 2016
thanks
thanks
Support Team posted this 10 March 2016
You're welcome!
Please let us know if you have any other questions/issues.
You're welcome! Please let us know if you have any other questions/issues.
