Slider in Joomla template
migrgic
migrgic posted this 04 March 2016
Is it possible to insert slider in header section just on home page, because since header is published on all pages so slider is visible on all pages also, and I want slider just on home page, but to stay in header section?
Please advise
Hi, Is it possible to insert slider in header section just on home page, because since header is published on all pages so slider is visible on all pages also, and I want slider just on home page, but to stay in header section? Please advise Thank you
Support Team posted this 04 March 2016
Why do you need it to be in the Header section? In any case, you can try to disable the Header control on the Home template, then go to the Page template for example (in this part you should have no slider in header), copy the existing header, revert to Home template, use Paste option (without Share) and put the Header. Then add the slider within the Header, it should bot appear on other pages.
Hi, Why do you need it to be in the Header section? In any case, you can try to disable the Header control on the Home template, then go to the Page template for example (in this part you should have no slider in header), copy the existing header, revert to Home template, use Paste option (without Share) and put the Header. Then add the slider within the Header, it should bot appear on other pages. Sincerely, Hella
