How to: (Hor. menu) each tab in a different color
kverweij
kverweij posted this 04 March 2016
I want to make a horizontaal menubar and have for each tab a different color. For example
http://demo.joomlabamboo.com/index.php?theme=dec11
How can i make that?
It's for a Joomla website.
Tips are welkom, thanks for that!
Hi, I want to make a horizontaal menubar and have for each tab a different color. For example http://demo.joomlabamboo.com/index.php?theme=dec11 How can i make that? It's for a Joomla website. Tips are welkom, thanks for that!
Support Team posted this 04 March 2016
There is no such direct option in the application. You should use the custom code to achieve that. Each item has its own class name, you can find it using the Inspect Element tool, then use that unique class name in the CSS code to specify the desired color for the item.
Hi, There is no such direct option in the application. You should use the custom code to achieve that. Each item has its own class name, you can find it using the Inspect Element tool, then use that unique class name in the CSS code to specify the desired color for the item. Sincerely, Hella
kverweij
Hi Hella,
Thanks for the very very quick answer!
Do you mean the Inspect Element tool from filebug? Ore is there one in Themler? I didm't know.
Hi Hella, Thanks for the very very quick answer! Do you mean the Inspect Element tool from filebug? Ore is there one in Themler? I didm't know.
Yes, I mean the inspect element tool from any browser you are using.
Hi, Yes, I mean the inspect element tool from any browser you are using. Sincerely, Hella
