Blank page Wordpress Category
Igor86
Igor86 posted this 08 March 2016
I have a website in wordpress and use themler . www.igorcardoso.com.br
I made the theme by themler , is working, but when I open the link category is all blank. category link : http://www.igorcardoso.com.br/category/blog/
But when I open the page by Themler to edit , the page appears with no problem, but the site does not appear.
I have a website in wordpress and use themler . www.igorcardoso.com.br I made the theme by themler , is working, but when I open the link category is all blank. category link : http://www.igorcardoso.com.br/category/blog/ But when I open the page by Themler to edit , the page appears with no problem, but the site does not appear.
tti2
tti2 posted this 09 March 2016
You have two links in menu:
- Blog as standard in Wordpress
- Category named Blog
Category links to blank (no head, no html) check in Wordpress: category, link, etc. ---- What did You set in Menu ?
Probably, in Themler You are looking at BLOG (page) that's why You think is ok --- You set the same NAME for two things:
BLOG (as standard blog) and named Your category BLOG that's why you are lost.
Best regards,
AS
You have two links in menu: - Blog as standard in Wordpress - Category named Blog Category links to blank (no head, no html) check in Wordpress: category, link, etc. ---- What did You set in Menu ? Probably, in Themler You are looking at BLOG (page) that's why You think is ok --- You set the same NAME for two things: BLOG (as standard blog) and named Your category BLOG that's why you are lost. Best regards, AS
Support Team posted this 09 March 2016
That link works if you activate non-Themler theme?
Hi, That link works if you activate non-Themler theme? Sincerely, Hella
Igor86
Igor86 posted this 09 March 2016
I'll explain. Access the site in a category , eg http://www.igorcardoso.com.br/category/blog/hospedagem/
Everything is blank, no header , content and footer . This link in the http://www.igorcardoso.com.br site menu is as HOSTING . If I access the same menu by Themler , you can view the page. But the site is blank.
I'm not good with English , I hope you understand.
I'll explain. Access the site in a category , eg http://www.igorcardoso.com.br/category/blog/hospedagem/ Everything is blank, no header , content and footer . This link in the http://www.igorcardoso.com.br site menu is as HOSTING . If I access the same menu by Themler , you can view the page. But the site is blank. I'm not good with English , I hope you understand.
Igor86
Igor86 posted this 11 March 2016
> Hi, > > That link works if you activate non-Themler theme? > > Sincerely, > Hella I'll explain. Access the site in a category , eg http://www.igorcardoso.com.br/category/blog/hospedagem/ Everything is blank, no header , content and footer . This link in the http://www.igorcardoso.com.br site menu is as HOSTING . If I access the same menu by Themler , you can view the page. But the site is blank. I'm not good with English , I hope you understand.
Support Team posted this 14 March 2016
So, does the issue happen with default WP theme?
Usually the plank page means some error/ Please enable error reporting to see if the issue is caused by the error:
https://css-tricks.com/snippets/wordpress/turn-on-wordpress-error-reporting/
Hi, So, does the issue happen with default WP theme? Usually the plank page means some error/ Please enable error reporting to see if the issue is caused by the error: https://css-tricks.com/snippets/wordpress/turn-on-wordpress-error-reporting/ Thank you, Olivia
