Custom Image for Menu Items
tti2
tti2 posted this 09 March 2016
Hi every one,
Stagger Lee in post http://answers.themler.com/questions/62863/custom-image-for-menu-items explain how to implement icon in menu using only CSS (without special plugins for WP: Menu Icons, etc.), thanks a lot for explanation.
What is done wrong in my case: I set special class in WP menu, add CSS in Themler but Icon does not appears ?
On the figure 1: Home and Produkty it seems, the icon there is - space but does not appears.
On the figure 2: Google also see the Bootstrap Font
Added CSS:
.bd-menuitem-20.menu > a::before {
margin: 0 5px 0 0;
padding: 0;
font-family: 'Billion Web Font';
font-style: normal;
font-weight: normal;
text-decoration: inherit;
text-align: center;
text-transform: none;
width: 1em;
content: '\123';
I give up. Where I made a mistake ? Please, help.
AS
Hi every one, Stagger Lee in post http://answers.themler.com/questions/62863/custom-image-for-menu-items explain how to implement icon in menu using only CSS (without special plugins for WP: Menu Icons, etc.), thanks a lot for explanation. What is done wrong in my case: I set special class in WP menu, add CSS in Themler but Icon does not appears ? On the figure 1: Home and Produkty it seems, the icon there is - space but does not appears. On the figure 2: Google also see the Bootstrap Font Added CSS: .bd-menuitem-20.menu > a::before { margin: 0 5px 0 0; padding: 0; font-family: 'Billion Web Font'; font-style: normal; font-weight: normal; text-decoration: inherit; text-align: center; text-transform: none; width: 1em; } .bd-menuitem-20.menu > a::before { content: '\123'; } I give up. Where I made a mistake ? Please, help. AS
Support Team posted this 10 March 2016
Maybe you will need to set the color to white as well as it might be black now. In any case please also provide a link to the site so we could review the code.
Hi, Maybe you will need to set the color to white as well as it might be black now. In any case please also provide a link to the site so we could review the code. Sincerely, Hella
tti2
tti2 posted this 14 March 2016
I provide link http://test.tti.pl/.
Please, take a look for main menu (set as responsive also for desktop).
For Home and Produkty are set additional CSS in WORDPRESS; in Themler are added CSS as pointed previously.
I also manipulated with color but no results I can't get icons in browser only spaces for them.
Best regards,
AS
Hi, I provide link http://test.tti.pl/. Please, take a look for main menu (set as responsive also for desktop). For Home and Produkty are set additional CSS in WORDPRESS; in Themler are added CSS as pointed previously. I also manipulated with color but no results I can't get icons in browser only spaces for them. Best regards, AS
Stagger Lee posted this 14 March 2016
You have visibility: hidden set for ::before, ::after selectors. Remove it in Themler options for menu items.
tti2
Visibility means NO VALUE for Menu Item Icon options in Themler.
It works. I wish say more then thank You.
It is a pity that the author of the post does not have the authority to close it and then assign (for example) any points of reputation to a person who solved the problem.
Once again thanks a lot for Your advice.
AS
Visibility means NO VALUE for Menu Item Icon options in Themler. It works. I wish say more then thank You. It is a pity that the author of the post does not have the authority to close it and then assign (for example) any points of reputation to a person who solved the problem. Once again thanks a lot for Your advice. Regards, AS
