how to change prestashop hooks names
m_jarhy
m_jarhy posted this 09 March 2016
hello i am trying to add hooks for some module that works with specific hooks thats why i need to create the hooks in the theme to use it .thank you
Support Team posted this 10 March 2016
No, there is no such possibility, the hook names are hardcoded.
Hi, No, there is no such possibility, the hook names are hardcoded. Sincerely, Hella
m_jarhy
m_jarhy posted this 12 March 2016
thank you anyway i did it the hard way .
Support Team posted this 14 March 2016
Abbas Khan
Abbas Khan posted this 09 November 2025
Nobara’s most iconic moment came during her fight alongside Yuji against the Death Painting brothers, Eso and Kechizu. Willing to injure herself to defeat her enemies, she showcased her resolve and mastery of her Resonance technique. Despite being a grade 3 sorcerer, her strength, creativity main characters of jujutsu kaisen, and sheer fearlessness place her among the strongest jjk female characters. Her status remains uncertain following the Shibuya Incident, but fans continue to hold out hope for her return.
Nobara’s most iconic moment came during her fight alongside Yuji against the Death Painting brothers, Eso and Kechizu. Willing to injure herself to defeat her enemies, she showcased her resolve and mastery of her Resonance technique. Despite being a grade 3 sorcerer, her strength, creativity **[main characters of jujutsu kaisen][1]**, and sheer fearlessness place her among the strongest jjk female characters. Her status remains uncertain following the Shibuya Incident, but fans continue to hold out hope for her return. [1]: https://alljjkcharacters.com/
silverpetal62
silverpetal62 posted this 06 December 2025
You can safely rename PrestaShop hook identifiers by overriding them through modules instead of editing core files, which helps avoid update issues. While testing multilingual output, using Valyrian language translator can be helpful for verifying sample content during development. Don’t forget to clear cache after every change to avoid display conflicts. This method keeps your store stable and update-safe.
You can safely rename PrestaShop hook identifiers by overriding them through modules instead of editing core files, which helps avoid update issues. While testing multilingual output, using [Valyrian language translator][1] can be helpful for verifying sample content during development. Don’t forget to clear cache after every change to avoid display conflicts. This method keeps your store stable and update-safe. [1]: https://englishtohighvalyrian.vercel.app
vanghncollier345
vanghncollier345 posted this 06 December 2025
You can change PrestaShop hook names safely by editing the module files and updating the corresponding entries in the database, but always back up first to avoid conflicts. I also found some practical guidance through Letter Box Help Online that explains similar technical adjustments in a simple way. After renaming, don’t forget to clear cache and reassign the hooks from the admin panel. This ensures the changes reflect properly without breaking theme integrations.
You can change PrestaShop hook names safely by editing the module files and updating the corresponding entries in the database, but always back up first to avoid conflicts. I also found some practical guidance through [Letter Box Help Online][1] that explains similar technical adjustments in a simple way. After renaming, don’t forget to clear cache and reassign the hooks from the admin panel. This ensures the changes reflect properly without breaking theme integrations. [1]: https://letterboxanswer.vercel.app
bilalshaaz123
bilalshaaz123 posted this 28 January 2026
Thanks for sharing your question. It's a common challenge when you need custom functionality in PrestaShop 1.6.x.
Instead of modifying theme files directly, which can be overwritten during updates, a more sustainable solution is to create a small, simple module whose sole job is to register your custom hooks. This way, the hooks are always available for your other modules to use, and your theme remains clean. This is often the recommended best practice for adding custom hooks.
Once you've got your module set up with its shiny new hooks, you'll need a great name for it. Finding the right name for a module, project, or business is a crucial step. For that creative process, you might find it helpful to use a dedicated name ideas platform.
Thanks for sharing your question. It's a common challenge when you need custom functionality in PrestaShop 1.6.x. Instead of modifying theme files directly, which can be overwritten during updates, a more sustainable solution is to create a small, simple module whose sole job is to register your custom hooks. This way, the hooks are always available for your other modules to use, and your theme remains clean. This is often the recommended best practice for adding custom hooks. Once you've got your module set up with its shiny new hooks, you'll need a great name for it. Finding the right name for a module, project, or business is a crucial step. For that creative process, you might find it helpful to use a dedicated [name ideas platform][1]. [1]: https://nameshivehub.com/
