Hi there when I create a slider inside a column the tab "slider" at the top of the screen to set all the options is not showing. I know as a work around you can right click on slider then click on more options but still you are not able to do the same things as with the tab.
Are any other people experiencing this problem?
Thanks, Ben
Hi there when I create a slider inside a column the tab "slider" at the top of the screen to set all the options is not showing. I know as a work around you can right click on slider then click on more options but still you are not able to do the same things as with the tab. Are any other people experiencing this problem? Thanks, BenLast edited 28 March 2016 by Support Team
