Themler on Wordpress editor
Paul Rodarte
Paul Rodarte posted this 14 March 2016
On a few websites that I have Themler installed, the backend editor does not display correctly. It is very hard to make changes because quite a bit of the visual disappears.
I have attached a sample screenshot of the editor and the site as it is displayed.
Anything that I can do to make the editor match.
On a few websites that I have Themler installed, the backend editor does not display correctly. It is very hard to make changes because quite a bit of the visual disappears. I have attached a sample screenshot of the editor and the site as it is displayed. Anything that I can do to make the editor match.
11 Comments
Support Team posted this 15 March 2016
Hello Paul,
as you know now Themler allows to edit content directly in Themler. It means that in fact page and posts content is built with shortcodes. If you open any page/post in WP admin back end you'll see it. So if you want customers to edit the content, you need to keep in mind the shortcode.
Moreover the Themler shortcodes are not interpreted by WP Visual editor and thus text is displayed in both Text and Visual tabs of the Edit Page/Post.
However if some content is just added to the Page/Post in WP admin back end without shortcodes, that's OK. The shortcodes are added automatically when theme is opened and saved in Themler.
Hello Paul, as you know now Themler allows to edit content directly in Themler. It means that in fact page and posts content is built with shortcodes. If you open any page/post in WP admin back end you'll see it. So if you want customers to edit the content, you need to keep in mind the shortcode. Moreover the Themler shortcodes are not interpreted by WP Visual editor and thus text is displayed in both Text and Visual tabs of the Edit Page/Post. However if some content is just added to the Page/Post in WP admin back end without shortcodes, that's OK. The shortcodes are added automatically when theme is opened and saved in Themler. Regards, Aileen
Paul Rodarte
Paul Rodarte posted this 15 March 2016
I don't think I explained properly. I am more concerned about the menu and other items that Themler creates. Not the content of the post/page.
When I am using themler to build the theme, it would be nice to be able to see what I am creating. I am using the Themler editor in Wordpress. It is part of the appeal of Themler, being able to visually see the menu, logo and title and such as they appear. Also being able to adjust them for normal, laptop, tablet and mobile. When the themler editor acts like this I have to do it all with the options panel and css, update and then review. Does that make sense.
I don't think I explained properly. I am more concerned about the menu and other items that Themler creates. Not the content of the post/page. When I am using themler to build the theme, it would be nice to be able to see what I am creating. I am using the Themler editor in Wordpress. It is part of the appeal of Themler, being able to visually see the menu, logo and title and such as they appear. Also being able to adjust them for normal, laptop, tablet and mobile. When the themler editor acts like this I have to do it all with the options panel and css, update and then review. Does that make sense.
Please try to switch off all the plug-ins and also check that the permission settings do not block the access to the Untitled_preview theme.
If that does not help, provide access to your site back end.
Hi, Please try to switch off all the plug-ins and also check that the permission settings do not block the access to the Untitled_preview theme. If that does not help, provide access to your site back end. Sincerely, Hella
roger36
roger36 posted this 02 June 2016
Hi. I have the same problem. Did the themler editor option come back after you switched off some plugins?
Regards Roger
Hi. I have the same problem. Did the themler editor option come back after you switched off some plugins? Regards Roger
Sct Design Group
Sct Design Group posted this 02 June 2016
I ask the same thing!!!!!
https://answers.themler.com/questions/82105/wysiwyg-editor-for-fronted-admin-without-going-to-themler-like-a-small-beaver-builder-kind
I ask the same thing!!!!! https://answers.themler.com/questions/82105/wysiwyg-editor-for-fronted-admin-without-going-to-themler-like-a-small-beaver-builder-kind
matthew.clark
matthew.clark posted this 03 June 2016
I am having the same issue but only use Themler to build the template not build the site content. Once any change is made to the theme it breaks the visuals for the header menus, however when you view the site as a guest its looks fine.
FYI i have disabled all plugins except for Themler-Core and still have the same issue.
I am having the same issue but only use Themler to build the template not build the site content. Once any change is made to the theme it breaks the visuals for the header menus, however when you view the site as a guest its looks fine. FYI i have disabled all plugins except for Themler-Core and still have the same issue.
roger36
roger36 posted this 03 June 2016
Still haven't figured out what is making the themler edit option to disappear from the wp menu...
Doesn't help to deactivate the other plugins....
Help!!
Still haven't figured out what is making the themler edit option to disappear from the wp menu... Doesn't help to deactivate the other plugins.... Help!!
roger36
The anwer was in the FAQ. It worked for me! :-)
Wordpress Themes
You do not see the Themler admin Menu within WordPress dashboard.
You may not see the Themler admin Menu if you disabled Theme Editor for all users in the WP wp-config.php file by adding the following line:
define('DISALLOW_FILE_EDIT', true);
Please change true value to false.
Please refer to to WP Codex for more details.
The anwer was in the FAQ. It worked for me! :-) Wordpress Themes You do not see the Themler admin Menu within WordPress dashboard. You may not see the Themler admin Menu if you disabled Theme Editor for all users in the WP wp-config.php file by adding the following line: define('DISALLOW_FILE_EDIT', true); Please change true value to false. Please refer to to WP Codex for more details.
alexarafatonline
alexarafatonline posted this 20 November 2025
I’ve run into similar issues with Themler before—sometimes the backend just won’t render properly, making edits frustrating. While troubleshooting, I thought about how much smoother workflows can be when you have reliable templates. For example, using a CapCut template like the iCal CapCut template saves so much time and ensures everything stays well-structured and polished. Having a dependable starting point, whether in video editing or website design, really reduces stress and helps you focus on creativity instead of fighting with the interface.
I’ve run into similar issues with Themler before—sometimes the backend just won’t render properly, making edits frustrating. While troubleshooting, I thought about how much smoother workflows can be when you have reliable templates. For example, using a CapCut template like the iCal [CapCut template][1] saves so much time and ensures everything stays well-structured and polished. Having a dependable starting point, whether in video editing or website design, really reduces stress and helps you focus on creativity instead of fighting with the interface. [1]: https://capcutssapk.com/ical-capcut-template/
escot5797
escot5797 posted this 29 December 2025
I’ve run into similar issues with Themler before—sometimes the backend just won’t render properly, making edits frustrating. While troubleshooting, I thought about how much smoother workflows can be when you have reliable templates. For example You can also use speed ramp CapCut template options to create smooth slow-motion and fast-paced cinematic effects effortlessly.
I’ve run into similar issues with Themler before—sometimes the backend just won’t render properly, making edits frustrating. While troubleshooting, I thought about how much smoother workflows can be when you have reliable templates. For example You can also use [speed ramp CapCut template][1] options to create smooth slow-motion and fast-paced cinematic effects effortlessly. [1]: https://moddedcapcut.com/speed-ramp-capcut-template/
najafirshad914
najafirshad914 posted this 4 days ago
https://www.robloxmodapk.live/ Do you want to improve your Roblox gameplay?
