As I can place a bullet in themler ? Please look at the
There is no separate Bullet list control in Themler, so please use the HTML control and insert it as the code:
http://www.w3schools.com/html/html_lists.asp
You have used the Text control, but you need to add the HTML control, you can find it under the Insert >> More controls.
Remove the first 3 lines and last 2 lines in your code and see if it works.
and inserted in this way and does not work..
check image please, You can find out more and help me please .
intenta insertar el control en nueva pagina (pagina en blanco) (me funciono el primer mes que use themler) ya despues descubri que no todo se puede modificar... o modificar de la pagina principal
sino inserta el control en solo donde venga <content> porque ahi esta en content-sidebars...
</content>
Please attach your exported theme so we could check why the issue appears.
