Add Section not working since this morning
weijmansaskia
weijmansaskia posted this 16 March 2016
Hi, the add section pop is not working properly.
If i click add section, or layout or newest, or any button, nothing is changing in the popup.
I have this problem with all templates.
Also in the 'native' themler on my mac, as in Wordpress itself.
Do you have any idea what;s going on?
ip-adress in WP is correct.
Thanks for the help, kind regards Saskia
Hi, the add section pop is not working properly. If i click add section, or layout or newest, or any button, nothing is changing in the popup. I have this problem with all templates. Also in the 'native' themler on my mac, as in Wordpress itself. Do you have any idea what;s going on? ip-adress in WP is correct. Thanks for the help, kind regards Saskia
16 Comments
Support Team posted this 17 March 2016
it seems to be temporary problems. I've just tried to work with pre-built sections: adding sections amd sections sorting are working without a problem.
Please try once more and let us know the results.
Hello, it seems to be temporary problems. I've just tried to work with pre-built sections: adding sections amd sections sorting are working without a problem. Please try once more and let us know the results. regards, Aileen
weijmansaskia
weijmansaskia posted this 17 March 2016
Hi Aileen,
I can add a section now, but not everything is working, i cannot filter of select, see screen film in attached .zip file
kind regards saskia
Hi Aileen, I can add a section now, but not everything is working, i cannot filter of select, see screen film in attached .zip file kind regards saskia
Support Team posted this 18 March 2016
Could you please update Themler to the latest Beta version (you may need to check the box next to "Get Beta updates" in your profile). After this please click "Apply to CMS" in Themler and F5, several times. Please let us know the result.
Hi, Could you please update Themler to the latest Beta version (you may need to check the box next to "Get Beta updates" in your profile). After this please click "Apply to CMS" in Themler and F5, several times. Please let us know the result. Sincerely, Nettie, BillionDigital Team
weijmansaskia
weijmansaskia posted this 18 March 2016
Hi Nettie,
Thanks, i did all those things and in stead of f5 i deleted all the cache and history and that worked. Thanks for the help! have a nice day, kind regards Saskia
Hi Nettie, Thanks, i did all those things and in stead of f5 i deleted all the cache and history and that worked. Thanks for the help! have a nice day, kind regards Saskia
Saskia, you are welcome! Please feel free to contact us in any other case.
Saskia, you are welcome! Please feel free to contact us in any other case. Sincerely, Nettie, BillionDigital Team
sap1970
sap1970 posted this 05 August 2017
Hi Support Team
I am having a issue here, I can not add any section, when attempt to add/swop out a section (in my case the footer) the login box appear and constantly flicker, i have to close it out without the adding the footer. please note, throughout this process at the bottom of the browser its showing "Waiting for themler..." then change to "Waiting for account.themler.io..." this also flickering constantly with the login box. what is causing this? and I have done the obvious - update the theme (wordpress) and using the latest version of themler, this is happening for all of the themes, is this a bug.
Sanjay Pandohie
Hi Support Team I am having a issue here, I can not add any section, when attempt to add/swop out a section (in my case the footer) the login box appear and constantly flicker, i have to close it out without the adding the footer. please note, throughout this process at the bottom of the browser its showing "Waiting for themler..." then change to "Waiting for account.themler.io..." this also flickering constantly with the login box. what is causing this? and I have done the obvious - update the theme (wordpress) and using the latest version of themler, this is happening for all of the themes, is this a bug. Sanjay Pandohie
Support Team posted this 07 August 2017
We are terribly sorry for the issue. Our developers are working to fix it, will be done as soon as possible.
Hi, We are terribly sorry for the issue. Our developers are working to fix it, will be done as soon as possible. Sincerely, Hella
zdrowiespzoo
zdrowiespzoo posted this 04 May 2025
Suddenly, it's no longer possible to add sections, and the templates are not loading. Please Help ?
bidoni5739
bidoni5739 posted this 16 September 2025
feature is not working since this morning, it might be due to a technical glitch, browser issue, or system update. Try refreshing the page, clearing cache, or switching to another device to fix the problem. Just like when you Find jobs online patience and trying different methods often lead to the right solution.
feature is not working since this morning, it might be due to a technical glitch, browser issue, or system update. Try refreshing the page, clearing cache, or switching to another device to fix the problem. Just like when you [Find jobs online][1] patience and trying different methods often lead to the right solution. [1]: https://pakijobs.pk/
romanosbambara
romanosbambara posted this 12 October 2025
j'ai fais une nouvelle installation de mon ordinateur mais il est impossible d'ajouter des sections et les modèles ne se chargent pas dans themler. pouvez vous nous aider?*
Take my online class
Take my online class posted this 12 October 2025
kind regards saskia
greenleafprojection
greenleafprojection posted this 24 December 2025
St. Thomas taxi rates can be higher than expected, but taxis offer a convenient way to explore the island. Always confirm fares upfront, as rates vary by distance, time, and passengers. For longer trips, agreeing on a flat rate makes travel easier and stress-free.
[St. Thomas taxi rates][1] can be higher than expected, but taxis offer a convenient way to explore the island. Always confirm fares upfront, as rates vary by distance, time, and passengers. For longer trips, agreeing on a flat rate makes travel easier and stress-free. [1]: https://majesticlimoandtour.com/how-much-is-a-taxi-in-st-thomas/
kolkatats01
kolkatats01 posted this 24 December 2025
The hierarchy of the hierarchy of these services tends to categorize Kolkata Female Escorts by their age, physical appearance as well as their background and the types of services they are willing to offer, which range from incalls--meeting at a private residence or hotel room, to outcalls, in which escorts accompany their clients to hotels, home or any other preferred location with the aim of facilitating flexibility and comfort. Clients are typically urged to take care to treat their escorts with respect, understanding that they are generally well-mannered, socially educated women who have higher rates representing their style and knowledge, and that satisfactory interactions depend on respect and appreciation for their efforts. Many agencies state that a majority of their escorts are not casual or inexpensive commodities however, they are upscale companions providing total attention, companionship and an atmosphere of class, which justifies their rates.
Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts, Kolkata Escorts,
The hierarchy of the hierarchy of these services tends to categorize [Kolkata Female Escorts](https://tannusinghal.in/kolkata-escorts.html) by their age, physical appearance as well as their background and the types of services they are willing to offer, which range from incalls--meeting at a private residence or hotel room, to outcalls, in which escorts accompany their clients to hotels, home or any other preferred location with the aim of facilitating flexibility and comfort. Clients are typically urged to take care to treat their escorts with respect, understanding that they are generally well-mannered, socially educated women who have higher rates representing their style and knowledge, and that satisfactory interactions depend on respect and appreciation for their efforts. Many agencies state that a majority of their escorts are not casual or inexpensive commodities however, they are upscale companions providing total attention, companionship and an atmosphere of class, which justifies their rates. [Kolkata Escorts](https://members2.boardhost.com/businessbooks3/msg/1763224136.html), [Kolkata Escorts](https://l2top.co/forum/members/tannu-singh.127890/), [Kolkata Escorts](https://3dprintboard.com/member.php?167317-tannusinghal), [Kolkata Escorts](https://golden-forum.com/memberlist.php?mode=viewprofile&u=210007), [Kolkata Escorts](https://www.toyotagtturbo.com/community/index.php?members/tannusinghal.26605/#about), [Kolkata Escorts](https://forum.callofwar.com/index.php?user/72202-tannusinghal/#about), [Kolkata Escorts](https://www.tabletennisdaily.com/forum/members/tannusinghal.149748/#about), [Kolkata Escorts](https://www.forum.or.id/members/tannusinghal.298932/), [Kolkata Escorts](https://www.warriorforum.com/members/tannusinghal.html?utm_source=internal&utm_medium=user-menu&utm_campaign=user-profile), [Kolkata Escorts](https://www.betting-forum.com/members/tannusinghal.130154/#about), [Kolkata Escorts](https://villagersandheroes.com/forums/members/tannusinghal.15887/#about), [Kolkata Escorts](https://forums.wolflair.com/members/tannusinghal.150784/#about), [Kolkata Escorts](https://forum.zidoo.tv/index.php?members/tannu-singhal.203305/), [Kolkata Escorts](https://forums.sonicretro.org/members/tannusinghal.65014/), [Kolkata Escorts](https://leasedadspace.com/members/tannusinghal/),
lyradaven
lyradaven posted this 05 January 2026
This kind of issue can be really frustrating, especially when basic WordPress functions stop working across different templates and systems. Clearing cache, checking JavaScript conflicts, or recent updates usually helps in such cases. For users who want clear guidance on my Aadhaar UIDAI Gov login and related online services, this resource can be helpful: my Aadhaar UIDAI Gov login.
This kind of issue can be really frustrating, especially when basic WordPress functions stop working across different templates and systems. Clearing cache, checking JavaScript conflicts, or recent updates usually helps in such cases. For users who want clear guidance on my Aadhaar UIDAI Gov login and related online services, this resource can be helpful: [my Aadhaar UIDAI Gov login][1]. [1]: https://myaadhaaruidaii.net/
mejov57740
mejov57740 posted this 06 January 2026
It appears that the section has not been functioning properly since this morning, which may be due to a technical issue or an unexpected system error. While there is no confirmed cause at this moment, there is a possibility that the problem could escalate if not addressed promptly. In some cases, prolonged downtime or unresolved errors could even lead to considerations of a lawsuit if critical operations are impacted. Users are advised to remain patient, as there is a chance that the issue may be resolved soon once the underlying cause is identified.
It appears that the section has not been functioning properly since this morning, which may be due to a technical issue or an unexpected system error. While there is no confirmed cause at this moment, there is a possibility that the problem could escalate if not addressed promptly. In some cases, prolonged downtime or unresolved errors could even lead to considerations of a [lawsuit][1] if critical operations are impacted. Users are advised to remain patient, as there is a chance that the issue may be resolved soon once the underlying cause is identified. [1]: https://nightfallgrouplawsuit.org/
babitareddyseo
babitareddyseo posted this 06 March 2026
I was planning a dinner outing and wanted someone stylish to accompany me. After searching online, I noticed several listings for Russian Escort Delhi services. The profiles appeared genuine and detailed, which helped build trust. The booking process was simple and the communication was polite. Having pleasant company during the evening made the outing feel more enjoyable and memorable.
I was planning a dinner outing and wanted someone stylish to accompany me. After searching online, I noticed several listings for [Russian Escort Delhi services][1]. The profiles appeared genuine and detailed, which helped build trust. The booking process was simple and the communication was polite. Having pleasant company during the evening made the outing feel more enjoyable and memorable. [1]: https://hotrussian.in/
