More styles for language switcher
Vitaliy WD
Vitaliy WD posted this 28 January 2015
Hello.
Now it is possible to insert Language Switcher only with Dropsown Bar style.
Is it possible to add more styles for Language Switcher?
For example, use the simple links for language switching or with button style.
To users: please vote for this topic if you have interest in this feature.
Hello. Now it is possible to insert **Language Switcher** only with **Dropsown Bar** style. Is it possible to add more styles for **Language Switcher**? For example, use the simple links for language switching or with button style. To users: please vote for this topic if you have interest in this feature.
8 Comments
Support Team posted this 29 January 2015
Unfortunately only dropdown style is available for the Language switcher now.
I've added your request to our wish list.
Hello Unfortunately only dropdown style is available for the Language switcher now. I've added your request to our wish list. Thank you, Olivia
Vitaliy WD
Vitaliy WD posted this 31 January 2015
Thanks for reply, Olivia.
Hope that it will be available in next updates.
To users: please don't forget to vote for this topic if you have interest in this feature.
Thanks for reply, Olivia. Hope that it will be available in next updates. **To users: please don't forget to vote for this topic if you have interest in this feature.**
Seppe
Seppe posted this 31 May 2016
Any news about this?
Themler has always the dropdown option
But when in Joomla the horizontal view is selected, it doesn't work.
How can we fix this?
Greetings
Any news about this? Themler has always the dropdown option But when in Joomla the horizontal view is selected, it doesn't work. How can we fix this? Greetings
Support Team posted this 01 June 2016
Hello Seppe,
it looks like you're facing with different issue.
The horizontal display of language selector works find with Joomla default theme
If you cannot handle with it I'd recommend that you create a new private topic and provide us access to Joomla admin back end
Hello Seppe, it looks like you're facing with different issue. The horizontal display of language selector works find with Joomla default theme !JoomlaLang.png! !ThemlerLAng'.png! If you cannot handle with it I'd recommend that you create a new private topic and provide us access to Joomla admin back end Regards, Aileen
shaulhadar
shaulhadar posted this 01 June 2016
Hi, i was wandering also how can i style the language switcher in wordpress so i can see flags, or flags + names....
is this possible inside themler?
Thanks...
Hi, i was wandering also how can i style the language switcher in wordpress so i can see flags, or flags + names.... is this possible inside themler? Thanks...
Hello Shaul,
in WordPress all style options are available in Language control, no more anything special for WP.
Hello Shaul, in WordPress all style options are available in Language control, no more anything special for WP. Regards, Aileen
d4quoise
d4quoise posted this 09 June 2017
I would like to use the flags in all values (items) of the drop down list.
Actually you only allowed to us at the Current Value with "Icon", "Short" or "Full" options, but I need it for all the values (including the sub-items of the dropdown menu.
If it's possible?
Other better option is if we can select/use/provide additionnally the option of Full name plus the Flag Icon aligned before or after text.
Thanks you,
I would like to use the flags in all values (items) of the drop down list. Actually you only allowed to us at the Current Value with "Icon", "Short" or "Full" options, but I need it for all the values (including the sub-items of the dropdown menu. If it's possible? Other better option is if we can select/use/provide additionnally the option of Full name plus the Flag Icon aligned before or after text. Thanks you,
Support Team posted this 19 June 2017
If it's possible?
No, unfortunately the Language control does not support any additional settings.
Themler team
Hi, > but I need it for all the values (including the sub-items of the dropdown menu. If it's possible? No, unfortunately the Language control does not support any additional settings. Thank you, Themler team
