do not have property window in themler wordpress
duygu
duygu posted this 22 March 2016
do not see property window as seen in quick overview videos
purchased themler then accidentally erased untitled1 and now can not see the previous secreen that I work on
now the screen shot of themler is attached as well as file from diagnostic tool
do not see property window as seen in quick overview videos purchased themler then accidentally erased untitled1 and now can not see the previous secreen that I work on now the screen shot of themler is attached as well as file from diagnostic tool
Support Team posted this 23 March 2016
That is a new interface of Themler changed last year. Looks like your theme was updated. Please let us know if you have any questions about the new interface.
Hi, That is a new interface of Themler changed last year. Looks like your theme was updated. Please let us know if you have any questions about the new interface. Sincerely, Hella
duygu
duygu posted this 23 March 2016
do you say that the previous interface is not being used anymore, it seemed more sophisticated
Yes, the old interface was changed to the new one you see now long time ago, you should have seen it if you have updated the theme before.
Hi, Yes, the old interface was changed to the new one you see now long time ago, you should have seen it if you have updated the theme before. Sincerely, Hella
duygu
ok, not a big problem but I bought themler on 11 March 2016 and started to use it on 22 March, that is why I got confused when I could not see the interface after I deleted untitled1, I thought I deleted sth. that should not be deleted, which does not make sense anyway, to erase a theme should not change the whole interface
thank you for answers
ok, not a big problem but I bought themler on 11 March 2016 and started to use it on 22 March, that is why I got confused when I could not see the interface after I deleted untitled1, I thought I deleted sth. that should not be deleted, which does not make sense anyway, to erase a theme should not change the whole interface thank you for answers
The theme you had was a default theme from the old version. And when you open it in the application, it restores the interface of the version in which it was saved. If you have updated that theme within the application using the red upgrade sign in the top bar of the application, you would see the new interface with that same theme.
Hi, The theme you had was a default theme from the old version. And when you open it in the application, it restores the interface of the version in which it was saved. If you have updated that theme within the application using the red upgrade sign in the top bar of the application, you would see the new interface with that same theme. Sincerely, Hella
lukemathew957
lukemathew957 posted this 24 October 2025
Hey! I faced this same “do not have property window” issue in Themler for WordPress it usually happens when some script tries to access the window object before it actually exists or in a context where it’s not available (like server-side). Try wrapping that code in a simple check like if (typeof window !== 'undefined') { ... } to make sure it only runs in the browser. Also, clear caches, disable any recent plugins, and test again sometimes Themler templates load scripts too early. This quick fix usually sorts it out!
lukemathew957
Hey! I ran into this same “do not have property window” issue while working with Themler in WordPress. In my case, it turned out that some scripts were running before the browser fully loaded, so wrapping them with a simple check like if (typeof window !== 'undefined') { ... } fixed it. Also, clearing the cache and disabling extra plugins helped a lot. You can check more about it here: https://estateagentsilford.co.uk/ hope this helps someone dealing with the same problem!
