In Phone template, Categories button instead of Menu bar
admin.netbutik
admin.netbutik posted this 26 March 2016
Can anybody tell me how to get a Categories type button instead of the standard horizontal menu bar that is there, in the Mobile Phone template by default.
(See Screenshot: On left, circled in red is what I don't want. On right, circled in green is similar to what I do want)
BTW: I'm using Prestashop but I think the answer could apply to any platform.
Thanks in advance
David C
Hi Can anybody tell me how to get a Categories type button instead of the standard horizontal menu bar that is there, in the Mobile Phone template by default. (See Screenshot: On left, circled in red is what I don't want. On right, circled in green is similar to what I do want) BTW: I'm using Prestashop but I think the answer could apply to any platform. Thanks in advance David C
Support Team posted this 28 March 2016
You mean that you only want to change the look of the menu button? That can be done under the Horizontal Menu >> Responsive. There you can change the text Menu to the desired one. And the Button icon as well.
Hi, You mean that you only want to change the look of the menu button? That can be done under the Horizontal Menu >> Responsive. There you can change the text Menu to the desired one. And the Button icon as well. Sincerely, Hella
admin.netbutik
admin.netbutik posted this 28 March 2016
Hi Hella,
No that's not quite right, I want find out how to change the Horizontal Menu (bar) for just a Categories Bar (that goes all the way across) then expands downward when selected, lika a lot of Phone themes have now days (see Screenshot)
Regards David C
Hi Hella, No that's not quite right, I want find out how to change the Horizontal Menu (bar) for just a Categories Bar (that goes all the way across) then expands downward when selected, lika a lot of Phone themes have now days (see Screenshot) Regards David C
Support Team posted this 29 March 2016
If you're referring to Horizontal Menu control you can achieve similar result in the way explained above by Hella.
Hmenu control allows to type any responsive menu text and choose any icon. The menu responsive button can be stretched to the width of page.
This is the only option. Themler's Hmenu does not have any other responsive options.
Themler's Vertical Menu does not have such option too.
Hi, If you're referring to Horizontal Menu control you can achieve similar result in the way explained above by Hella. Hmenu control allows to type any responsive menu text and choose any icon. The menu responsive button can be stretched to the width of page. This is the only option. Themler's Hmenu does not have any other responsive options. Themler's Vertical Menu does not have such option too. Thank you, Olivia
admin.netbutik
Is Solution
admin.netbutik posted this 29 March 2016
Ok Olivia, I'll look into it more then :-)
Close this thread then, Thanks.
David C
Ok Olivia, I'll look into it more then :-) Close this thread then, Thanks. David C
