On my Joomla templates when I select Post from the template drop down. It automatically switches to 404 Template. I cannot edit the Post template.
Any ideas? Anybody else have this problem.
Using v.256 (desktop install)
and Joomla CMS
and Joomla CMS
Also does this if I create a new theme, do nothing to it and just try to select Post from the template drop down. It hesitates for a second then pulls up the 404 template.
Anybody else seeing this?
Also does this if I create a new theme, do nothing to it and just try to select Post from the template drop down. It hesitates for a second then pulls up the 404 template. Anybody else seeing this?Hi,
Could you please provide an access to your site so we could review the settigs and check why the issue appears.
I have moved the caseto private so you can post the details here.
It's not on the site, it's on my local computer. I do not have Themler installed on the server, just the template. See attachment. And like I said it does this on every template, even if I create a brand new one and do nothing to it, as soon as I click on the Post template it switches to the 404 template. Every time, on every template.
It's not on the site, it's on my local computer. I do not have Themler installed on the server, just the template. See attachment. And like I said it does this on every template, even if I create a brand new one and do nothing to it, as soon as I click on the Post template it switches to the 404 template. Every time, on every template.Also when I click on Default Template is says default template is disabled... not sure if this is related to Post template issue.
Also when I click on Default Template is says default template is disabled... not sure if this is related to Post template issue.Hi Nate,
This issue sounds really familiar to me.
I'm pretty sure that it was resolved in the latest desktop Themler version:
http://downloads.themler.com/Themler.1.0.247.07e3e.exe
Please try to reinstall the software (do NOT remove CMS Content, this is extremely important) and let us know the result.
Ivan
Look like this is bug in Desktop version. I've assigned this issue to our developers. We'll let you know when we receive any news from them. The reported issue will be fixed in one of the future Themler updates. Thank you for bug report.
In order to fix the reported issue you can use workaround. Please follow these steps:
Open Admin panel for Joomla.
Open Menus > Main Menu.
Open Post.
Click Select button on Select Article field.
Select Blog Post 1
Click 'Save' button.
Click 'Refresh Content' Button in themler.
This should help. We apologize for the inconvenience. Please keep us posted about the progress.
Themler Team
I have a similar problem, every time I want to switch to Product template from drop down menu Default template is selected.
This problem is recent and didn't appear before. http://www.kutjevo.com/test/
Please advise
Hi, I have a similar problem, every time I want to switch to Product template from drop down menu Default template is selected. This problem is recent and didn't appear before. http://www.kutjevo.com/test/ Please adviseHello migrgic ,
this issue should be resolved in the latest Themler version (v319). Please update your theme if needed. If it's not a problem please submit a new private topic and provide access credentials to Joomla admin back end
