I see the Windows version for Themler has Prestashop Version 1.6.0.8 and that if you use the Themler on actual Prestashop version 1.6.1.4 its gets broken really fast some of the things dont work, I've even opened a Ticket so check that out.
I think some of the things need to be adjusted to the new Prestashop version so the Themler can Work again until the bugs are fixed I gonna use the older version of Prestashop.
Hello, I see the Windows version for Themler has Prestashop Version 1.6.0.8 and that if you use the Themler on actual Prestashop version 1.6.1.4 its gets broken really fast some of the things dont work, I've even opened a Ticket so check that out. I think some of the things need to be adjusted to the new Prestashop version so the Themler can Work again until the bugs are fixed I gonna use the older version of Prestashop. Thanks
