Hi there,
A quick question please:
I have designed a Homepage and one other page for a website so that my client can see if it is what they are after. If they would like an alternative Homepage creating so that they can compare the two, how would I go about setting that up so that it does not interfere with the original Homepage?
The reason I ask is that after creating the original Homepage, I went to file menu and selected 'NEW', saved it under a totally different name and then started to create a new homepage design variation, but when reviewing the original Homepage, parts of it had changed to the newly created one!
Is there something else I should have done, as it would be nice to supply an alternative to the client sometimes.
Any help gratefully received.
Regards Krav
Hi there, A quick question please: I have designed a Homepage and one other page for a website so that my client can see if it is what they are after. If they would like an alternative Homepage creating so that they can compare the two, how would I go about setting that up so that it does not interfere with the original Homepage? The reason I ask is that after creating the original Homepage, I went to file menu and selected 'NEW', saved it under a totally different name and then started to create a new homepage design variation, but when reviewing the original Homepage, parts of it had changed to the newly created one! Is there something else I should have done, as it would be nice to supply an alternative to the client sometimes. Any help gratefully received. Regards Krav
