Position right from Slideshow
damien.tochtermann
damien.tochtermann posted this 04 April 2016
Hello, i'd like to create a position which will be placed right from Slideshow .
There will be a module in this position.
Please help me ;-)
Hello, i'd like to create a position which will be placed right from Slideshow . There will be a module in this position. Please help me ;-)
Support Team posted this 04 April 2016
You can add two columns, one with the slider and the second one with the module position.
Hi, You can add two columns, one with the slider and the second one with the module position. Sincerely, Hella
damien.tochtermann
damien.tochtermann posted this 11 April 2016
hello, stupid question, but how can I insert the photos I want in my slider ?? In joomla I can't find it and in template not...
hello, stupid question, but how can I insert the photos I want in my slider ?? In joomla I can't find it and in template not... Thanks
Support Team posted this 11 April 2016
You use the Themler slider? Then you can edit slides within Themler only. There you can choose the slide background.
Hi, You use the Themler slider? Then you can edit slides within Themler only. There you can choose the slide background. Sincerely, Hella
damien.tochtermann
damien.tochtermann posted this 12 April 2016
Could you explain me with screeenshot how to make it ? thanks !!
Please have a look to the screen shot:
Hi, Please have a look to the screen shot: !slide-background.png! Sincerely, Hella
damien.tochtermann
damien.tochtermann posted this 14 April 2016
This is ok, but when I use your sections etc, this Slider menu don't appear...
Support Team posted this 19 April 2016
Hello Damien,
pre-built sections include Themler controls, including slider.
You may switch to Layout View and select control you need
Hello Damien, pre-built sections include Themler controls, including slider. You may switch to Layout View and select control you need !LayoutView.png! regards, Aileen
