Hi, it would be great if there is a export function for the header :)
Thanks and have a nice day,
Saskia
Saskia
You can export the header as the section. Or you mean something different?
Hi Hella
thanks for the quick reply. My header is a canvas, see attachement. So I cannot export it. Do you have a suggestion? Or do I have to put the canvas in the section?
Kind regards Saskia
Yes, insert the section within header and then your canvas inside it. In the new version we do have Section:Canvas that already combines the section and canvas inside it.
Hi Hella,
Oke thanks i will cope the canvas and paste it into the section:canvas.
Also I am having the same problem with adding sections in dynamic page as another member, i will ask it in that forum post.
Kind regards Saskia
already solved it... :)
euhm, not solved, i will make a private post :)
> already solved it... :) euhm, not solved, i will make a private post :)Hi,
Yes please, post the problem in the related ticket. I'm closing this one now.
