margins for mobile?
alberdimb
alberdimb posted this 05 April 2016
Where I can change the margins for mobile?
you prune help me
Where I can change the margins for mobile? you prune help me
16 Comments
Support Team posted this 06 April 2016
Please attach your theme so we could review the settings. Do not forget to include the editor in the exported theme.
Hi, Please attach your theme so we could review the settings. Do not forget to include the editor in the exported theme. Sincerely, Hella
alberdimb
alberdimb posted this 06 April 2016
Here I send you what
Support Team posted this 11 April 2016
please try to verify the Margin and Padding settings under Posts tab. Namely for Posts
and for Post and Post Content
If it does not help please re-export template using option File >> Export as ZIP
Because I cannot open the attached theme.
Hello, please try to verify the Margin and Padding settings under Posts tab. Namely for Posts !PostsMarg.png! and for Post and Post Content !PostsMarg1.png! If it does not help please re-export template using option File >> Export as ZIP !ExportZIP.png! Because I cannot open the attached theme. Regards, Aileen
alberdimb
alberdimb posted this 11 April 2016
I export it as you indicate, and I save a file .tgz
That I can not attach
Invalid file extension. Only images, text files, artx and zip archives are allowed
In the previous place that .tgz sent in a .zip
As I can do to resend
I export it as you indicate, and I save a file .tgz That I can not attach Invalid file extension. Only images, text files, artx and zip archives are allowed In the previous place that .tgz sent in a .zip As I can do to resend
alberdimb
alberdimb posted this 12 April 2016
you help me to get it you can send?
Sorry for the delay.
You can put .tgz in .zip archive or add additional .zip extension manually.
Hi, Sorry for the delay. You can put .tgz in .zip archive or add additional .zip extension manually. Thank you, Olivia
alberdimb
alberdimb posted this 18 April 2016
I'll resubmit.
Please I need a solution as soon as possible
I'll resubmit. Please I need a solution as soon as possible
Support Team posted this 21 April 2016
unfortunately I failed to open the attached theme.
May I ask you to upload your site online and provide us with link to the page which demonstrates the issue?
Hello, unfortunately I failed to open the attached theme. May I ask you to upload your site online and provide us with link to the page which demonstrates the issue? regards, Aileen
alberdimb
alberdimb posted this 21 April 2016
On this page the content part is adapted to mobile but has much room
http://nauticafolino.com.ar/index.php/repuestos
You can download it the topic in this link
http://nauticafolino.com.ar/themler/folino_160418.tgz
Please I need a quick response
On this page the content part is adapted to mobile but has much room http://nauticafolino.com.ar/index.php/repuestos You can download it the topic in this link http://nauticafolino.com.ar/themler/folino_160418.tgz Please I need a quick response
Support Team posted this 28 April 2016
Please see the attached screenshot:
Hi, Sorry for the delay. Please see the attached screenshot: !post-margin.png! Thank you, Olivia
alberdimb
alberdimb posted this 28 April 2016
Please I can give a useful answer?
I need to fix this problem
Please I can give a useful answer? I need to fix this problem
Support Team posted this 04 May 2016
I'm terribly sorry for delay in response.
Could you please provide access to your Magento admin back end so we could check the solution exactly at your theme and site.
Hello, I'm terribly sorry for delay in response. Could you please provide access to your Magento admin back end so we could check the solution exactly at your theme and site. regards, Aileen
alberdimb
alberdimb posted this 04 May 2016
I pass the data on a private ticket
Please I need an urgent solution, I can not wait again six days
ticket id: 77612
I pass the data on a private ticket Please I need an urgent solution, I can not wait again six days ticket id: 77612
Support Team posted this 06 May 2016
actually the response is the same as was provided before. You need to change the left and right margins
You see that solution is applied to your theme and it works.
If I misunderstood you, please attach screenshot how you'd like this page to look.
Hello, actually the response is the same as was provided before. You need to change the left and right margins !LaftMargin.png! You see that solution is applied to your theme and it works. If I misunderstood you, please attach screenshot how you'd like this page to look. regards, Aileen
alberdimb
alberdimb posted this 06 May 2016
I made the switch indicating me.
In the editor it looks good.
But when I save changes on the web is still seen bad
example: http://nauticafolino.com.ar/index.php/repuestos
I made the switch indicating me. In the editor it looks good. But when I save changes on the web is still seen bad example: http://nauticafolino.com.ar/index.php/repuestos
Support Team posted this 11 May 2016
You can edit post Margin in Ribbon > Layout > Contents & Sidebars > Shape Options > Margin.
I alredy fix margin for mobile view on your site.
Themler Team
Hi, You can edit post Margin in Ribbon > Layout > Contents & Sidebars > Shape Options > Margin. !post-margin.png! I alredy fix margin for mobile view on your site. Thank you, Themler Team
