Install Themler in Wordpress on One.com
hovmedia
hovmedia posted this 07 April 2016
Hi!
I have created several websites on differnt domains using Themler and Worpress. Adding Themler as a plugin have never been a problem. But I am not able to make it work at One.com. I have activated theme and installed plugin but Themler do not appear in the menu in control panel.
I get an errormessage if i klick edit button in template menu. It says that I do not have the right access privileges. Are there any issues with write access to wp-admin folder etc???
Hi! I have created several websites on differnt domains using Themler and Worpress. Adding Themler as a plugin have never been a problem. But I am not able to make it work at One.com. I have activated theme and installed plugin but Themler do not appear in the menu in control panel. I get an errormessage if i klick edit button in template menu. It says that I do not have the right access privileges. Are there any issues with write access to wp-admin folder etc???
Support Team posted this 11 April 2016
you may not see Themler menu in the left side panel if theme was saved without 'Include Themler...' option. Please check it.
Please do not use 'Edit in Themler' button to open Themler, open theme using Themler menu.
Hello, you may not see Themler menu in the left side panel if theme was saved without 'Include Themler...' option. Please check it. Please do not use 'Edit in Themler' button to open Themler, open theme using Themler menu. Regards, Aileen
hovmedia
hovmedia posted this 11 April 2016
Hi!
Thanks for reply, but I were able to solve it. I used a "one click" Wordpress automatic installation. A service they have in the control panel for the web hotel. This installation have some restrictions that blocks Themler. A clean Wordpress installation solved it.
Johnny
Hi! Thanks for reply, but I were able to solve it. I used a "one click" Wordpress automatic installation. A service they have in the control panel for the web hotel. This installation have some restrictions that blocks Themler. A clean Wordpress installation solved it. Johnny
Hello Johnny,
you're welcome. Let us know if you have additional questions
Hello Johnny, you're welcome. Let us know if you have additional questions regards, Aileen
