Page widthe
williamvanveen1988
williamvanveen1988 posted this 07 April 2016
Dear Support,
Me page with on page themplate is strange. I doesn't get it tottaly widthe.
See the page overhere:
http://www.wveen.com/website-laten-maken
I try evrywhere to setup page widthe and it doesn't work out.
Kind regards,
William
Dear Support, Me page with on page themplate is strange. I doesn't get it tottaly widthe. See the page overhere: http://www.wveen.com/website-laten-maken I try evrywhere to setup page widthe and it doesn't work out. Kind regards, William
Support Team posted this 07 April 2016
Your settings are a bit strange. As far as I see, you have added the columns in the content and then in the first column that is set to be 50% width the content is displayed with the 100 screen width parameter that is causing this issue. Remove all the 100vw width values and use one column in the content.
Sincere;y,
Hi, Your settings are a bit strange. As far as I see, you have added the columns in the content and then in the first column that is set to be 50% width the content is displayed with the 100 screen width parameter that is causing this issue. Remove all the 100vw width values and use one column in the content. Sincere;y, Hella
williamvanveen1988
williamvanveen1988 posted this 08 April 2016
Thanks for your fast reply.
I have created a other template and it works now.
Only when i go to the start page the themplate is away.
Other pages working well. When you go to other page and go back to the homepage the themplate works normal. See picture:
Kind regards,
William
Thanks for your fast reply. I have created a other template and it works now. Only when i go to the start page the themplate is away. Other pages working well. When you go to other page and go back to the homepage the themplate works normal. See picture: !2016-04-08-13-34-28.jpg! Kind regards, William
Support Team posted this 08 April 2016
I see the start page just fine. maybe some cache issues in browser or site?
Hi, I see the start page just fine. maybe some cache issues in browser or site? Sincerely, Hella
williamvanveen1988
Thanks i will check this
Manny thanks for support
It's happening sometimes. Not always. Realy strange
Kind regards,
William
Thanks i will check this Manny thanks for support It's happening sometimes. Not always. Realy strange Kind regards, William
OK, please let us know if it happens again.
Hi, OK, please let us know if it happens again. Sincerely, Hella
