System font not showing on computers it's not installed on
CharlieT
CharlieT posted this 11 April 2016
Hi guys,
I've set my headings to be Bebas Neu, a system font in my wordpress theme. I've attmepted to edit the CSS:
 @font-face {
    font-family: 'bebas_neueregular';
    src: url('bebasneue-webfont.eot');
    src: url('bebasneue-webfont.eot?#iefix') format('embedded-opentype'),
         url('bebasneue-webfont.woff2') format('woff2'),
         url('bebasneue-webfont.woff') format('woff'),
         url('bebasneue-webfont.ttf') format('truetype'),
         url('bebasneue-webfont.svg#bebas_neueregular') format('svg');
    font-weight: normal;
    font-style: normal;
It's still not showing on devices the font isn't installed on. I read that SSL (HTTPS) could be an issue also. Can you advise what I'm doing wrong?
The site is https://soldieron.org.au
Cheers,
Charlie.
Hi guys, I've set my headings to be Bebas Neu, a system font in my wordpress theme. I've attmepted to edit the CSS: @font-face { font-family: 'bebas_neueregular'; src: url('bebasneue-webfont.eot'); src: url('bebasneue-webfont.eot?#iefix') format('embedded-opentype'), url('bebasneue-webfont.woff2') format('woff2'), url('bebasneue-webfont.woff') format('woff'), url('bebasneue-webfont.ttf') format('truetype'), url('bebasneue-webfont.svg#bebas_neueregular') format('svg'); font-weight: normal; font-style: normal; } It's still not showing on devices the font isn't installed on. I read that SSL (HTTPS) could be an issue also. Can you advise what I'm doing wrong? The site is https://soldieron.org.au Cheers, Charlie.
11 Comments
Stagger Lee posted this 11 April 2016
Is your bootstrap.css in same folder (level) as fonts ? According to paths it should be.
CharlieT
CharlieT posted this 12 April 2016
Hi Stagger Lee,
Bootstrap.css is in the same folder as the fonts folder. I have copied the ttf and woff files into the fonts folder. Am I missing a step? Could the SSL certificate be an issue?
Cheers,
Charlie.
Hi Stagger Lee, Bootstrap.css is in the same folder as the fonts folder. I have copied the ttf and woff files into the fonts folder. Am I missing a step? Could the SSL certificate be an issue? Cheers, Charlie.
Stagger Lee posted this 12 April 2016
No "fonts folder". Font raw files should be where bootstrap.css is. Or change paths to "url('fonts/bebasneue-webfont.woff2') format('woff2'),".
Do same for preview theme, if you want to see changes in Themler.
No "fonts folder". Font raw files should be where bootstrap.css is. Or change paths to "url('fonts/bebasneue-webfont.woff2') format('woff2'),". Do same for preview theme, if you want to see changes in Themler.
CharlieT
CharlieT posted this 13 April 2016
I copied the font files into my theme's folder, on the same level as bootstrap.css:
The problems remains. Am I missing something here?
I copied the font files into my theme's folder, on the same level as bootstrap.css: !font2.png! The problems remains. Am I missing something here?
Stagger Lee posted this 13 April 2016
It is just one part of job. Find in forum topic how to do second part. It is new, maybe from one week ago. You need to repeat it for theme_preview folder.
CharlieT
CharlieT posted this 14 April 2016
I've repeated that step for the preview folder to no avail and can't find the recent topic in the forum. can you remember what it was called?
CharlieT
I found this thread: http://answers.themler.com/questions/72076/can-t-find-themler-additional-css
Modified the CSS to:
 @font-face {
    src: url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.eot');
    src: url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.eot?#iefix') format('embedded-opentype'),
         url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.woff2') format('woff2'),
         url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.woff') format('woff'),
         url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.ttf') format('truetype'),
         url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.svg#bebas_neueregular') format('svg');
    font-style: normal;}
Still no luck :(
I found this thread: http://answers.themler.com/questions/72076/can-t-find-themler-additional-css Modified the CSS to: @font-face { font-family: 'bebas_neueregular'; src: url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.eot'); src: url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.eot?#iefix') format('embedded-opentype'), url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.woff2') format('woff2'), url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.woff') format('woff'), url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.ttf') format('truetype'), url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.svg#bebas_neueregular') format('svg'); font-weight: normal; font-style: normal;} Still no luck :(
Stagger Lee posted this 14 April 2016
https://answers.themler.com/questions/41734/how-to-add-chinese-font-like-microsoft-yahei/
CharlieT
Is Solution
Stagger Lee, if I ever meet you I will buy you 7 beers!
The fix for me:
Added font files into below path
Added the below CSS:
 @font-face {
Then went into Design >> Fonts >> Font Options and then pasted bebas_neueregular as the headings font.
Thanks Stagger Lee, you rock!
Stagger Lee, if I ever meet you I will buy you 7 beers! The fix for me: Added font files into below path Added the below CSS: @font-face { font-family: 'bebas_neueregular'; src: url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.eot'); src: url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.eot?#iefix') format('embedded-opentype'), url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.woff2') format('woff2'), url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.woff') format('woff'), url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.ttf') format('truetype'), url('https://www.soldieron.org.au/wp-content/themes/newseasonSO/bebasneue-webfont.svg#bebas_neueregular') format('svg'); font-weight: normal; font-style: normal;} Then went into Design >> Fonts >> Font Options and then pasted bebas_neueregular as the headings font. Thanks Stagger Lee, you rock!
You can use relative paths, as you did first time.
Mostly problem is if you forgot to paste font files in theme_preview folder. That it is why they allways work in Themler screen with absolute paths.
You can use relative paths, as you did first time. Mostly problem is if you forgot to paste font files in theme_preview folder. That it is why they allways work in Themler screen with absolute paths.
CharlieT
CharlieT posted this 15 April 2016
Thanks for the info! I will remember this for next time.
