Joomla - forms
maciar91
maciar91 posted this 11 April 2016
On my site I have a form of Fabrik.
Template created by Themler expands the field to the length of the sheet (1.jpg)
How to set the display as shown in the second file?
On my site I have a form of Fabrik. Template created by Themler expands the field to the length of the sheet (1.jpg) How to set the display as shown in the second file?
18 Comments
Support Team posted this 12 April 2016
Please provide a link to the page with the form so we could review the styles.
Hi, Please provide a link to the page with the form so we could review the styles. Sincerely, Hella
net38
net38 posted this 31 May 2016
I have exactly the same problem.
Best Regards,
Hi, I have exactly the same problem. Best Regards,
bnk88
bnk88 posted this 31 May 2016
My too
Hi, My too
Support Team posted this 01 June 2016
Please provide links to the pages with the issue.
Hi, Please provide links to the pages with the issue. Sincerely, Hella
net38
net38 posted this 01 June 2016
http://fabrik.cryptlan.com/
net38
Do you need access to backend?
Support Team posted this 02 June 2016
@net38,
some selector of your form cannot be accessed via Themler. So I'd recommend that you change their width via custom CSS code. Add it under Home tab >> Settings >> Additional CSS
select, textarea, input[type="text"], input[type="password"], input[type="datetime"], input[type="datetime-local"], input[type="date"], input[type="month"], input[type="time"], input[type="week"], input[type="number"], input[type="email"], input[type="url"], input[type="search"], input[type="tel"], input[type="color"], .form-control{
width:inherit!important;
@net38, some selector of your form cannot be accessed via Themler. So I'd recommend that you change their width via custom CSS code. Add it under Home tab >> Settings >> Additional CSS select, textarea, input[type="text"], input[type="password"], input[type="datetime"], input[type="datetime-local"], input[type="date"], input[type="month"], input[type="time"], input[type="week"], input[type="number"], input[type="email"], input[type="url"], input[type="search"], input[type="tel"], input[type="color"], .form-control{ width:inherit!important; } Regards, Aileen
net38
net38 posted this 02 June 2016
The label is above the field and not at the left of the field
How can I change it?
Best Regards,
The label is above the field and not at the left of the field How can I change it? Best Regards,
Support Team posted this 03 June 2016
you may enhance the previous CSS with
float:left
But most probably the input size shuold be reduced in this case:
width:30%!important;
float:left;
Hello, you may enhance the previous CSS with float:left But most probably the input size shuold be reduced in this case: select, textarea, input[type="text"], input[type="password"], input[type="datetime"], input[type="datetime-local"], input[type="date"], input[type="month"], input[type="time"], input[type="week"], input[type="number"], input[type="email"], input[type="url"], input[type="search"], input[type="tel"], input[type="color"], .form-control{ width:30%!important; float:left; } Regards, Aileen
net38
net38 posted this 03 June 2016
thanks,
WORKS
thanks, **WORKS**
jeanmarcvieux
jeanmarcvieux posted this 15 January 2018
I have the same problem, I've copied and pasted your CSS adding but the form is still "block" see the capture1.png
I can't give you a link the server is secures by IP filtering.
Thanks for your help
Jean-Marc
Hi, I have the same problem, I've copied and pasted your CSS adding but the form is still "block" see the capture1.png And It should be like the capture2.png I can't give you a link the server is secures by IP filtering. Thanks for your help Jean-Marc
Support Team posted this 15 January 2018
Unfortunately we cannot provide you any solution by this screen shot only. Maybe you could create a duplication of the site or export the theme with the content and editor included (if the form is a content and not a module or plug-in).
Hi, Unfortunately we cannot provide you any solution by this screen shot only. Maybe you could create a duplication of the site or export the theme with the content and editor included (if the form is a content and not a module or plug-in). Sincerely, Hella
jeanmarcvieux
jeanmarcvieux posted this 16 January 2018
Hi hella and thanks for replying.
Here a link : https://www.intelartifice.fr/a2s/index.php/dossier-expert
Hi hella and thanks for replying. Here a link : https://www.intelartifice.fr/a2s/index.php/dossier-expert Regards,
jeanmarcvieux
Re-
there is a progress bar in inscription form, and it's doesn't works still ans I don't find any way to fix it.
Re- there is a progress bar in inscription form, and it's doesn't works still ans I don't find any way to fix it.
jeanmarcvieux
jeanmarcvieux posted this 17 January 2018
I tried with insert the form in article and add some CSS in it but still the same :
User agent stylesheet : html { display: block; }
I found clouzoom.js and i removed it no more result.
I add some enhancement in additional CSS but still the same.
Even in themler - design - input - more option /inline-block/ choice
Hi, I tried with insert the form in article and add some CSS in it but still the same : User agent stylesheet : html { display: block; } I found clouzoom.js and i removed it no more result. I add some enhancement in additional CSS but still the same. Even in themler - design - input - more option /inline-block/ choice Regards
jeanmarcvieux
Anyone has a solution?
I'm still searching an issue. It's insane!!! I get crazy wih it
??? Anyone has a solution? I'm still searching an issue. It's insane!!! I get crazy wih it
jeanmarcvieux
jeanmarcvieux posted this 18 January 2018
Hi, I fixed it.
Just add in additional CSS
.control-group {
margin-top: 10px;
width: inherit!important;
display: inline-block;
Hi, I fixed it. Just add in additional CSS .control-group { margin-top: 10px; width: inherit!important; display: inline-block; }
