Border of columns
Bayern
Bayern posted this 13 April 2016
i have a Joomla Template with three columns (with Joomla Positions) at the bottom of content
i want to have a border (or seperator) between the coulmns and these borders (seperators) schould always have the full hight - regardless of the content of the modules
Do you have an idea?
Hello, i have a Joomla Template with three columns (with Joomla Positions) at the bottom of content i want to have a border (or seperator) between the coulmns and these borders (seperators) schould always have the full hight - regardless of the content of the modules Do you have an idea?
You can choose one of the presets under the Columns tab >> Styling. There is one with the border. Or add a border for each column. You can access the column options under the Columns tab >> Column >> Border.
Hi, You can choose one of the presets under the Columns tab >> Styling. There is one with the border. Or add a border for each column. You can access the column options under the Columns tab >> Column >> Border. Sincerely, Hella
Bayern
Hi Hella,
i tried both - with preset (is only for two columns) and with each column
but the hight of the border is always depending on the content
i attach the zip and it would be glad if you can help
Sincerely
Jürgen
Hi Hella, i tried both - with preset (is only for two columns) and with each column but the hight of the border is always depending on the content i attach the zip and it would be glad if you can help Sincerely Jürgen
Bayern
Bayern posted this 14 April 2016
I got it!
Sidebar - no background
Section - the desired background color
Columns - set to full hight (FlexBox), background color white
Second Column (the middle) - border left and right - no color
and voila :D
I got it! Sidebar - no background Section - the desired background color Columns - set to full hight (FlexBox), background color white Second Column (the middle) - border left and right - no color and voila :D !1.png!
Support Team posted this 19 April 2016
Hello Jürgen,
that's great that you have found the solution.
You're welcome.
If you have additional questions please feel free to ask
Hello Jürgen, that's great that you have found the solution. You're welcome. If you have additional questions please feel free to ask regards, Aileen
