Using Sections and corresponding text in WP visual editor
Krav
Krav posted this 13 April 2016
I'm creating a website using Themler 'Sections', then editing text and images as necessary. Its a nice way to put web pages together!
At the moment no corresponding titles, text or image code is appearing in my WP admin 'visual editor' panel?
Do I need to do anything to make this happen? (This is a one page website with multiple sections running down the page.)
Any help welcome.
Thanks Krav.
Hi, I'm creating a website using Themler 'Sections', then editing text and images as necessary. Its a nice way to put web pages together! At the moment no corresponding titles, text or image code is appearing in my WP admin 'visual editor' panel? Do I need to do anything to make this happen? (This is a one page website with multiple sections running down the page.) Any help welcome. Thanks Krav.
It depends on where you added Sections.
The only way to edit Section via WP ot Joomla admin panel is to add these Section into the content area (with green border):
In this case the Section will be converted to the CMS content (post/page or article).
Hi, It depends on where you added Sections. The only way to edit Section via WP ot Joomla admin panel is to add these Section into the content area (with green border): !add-content-new.png! In this case the Section will be converted to the CMS content (post/page or article). Thank you, Olivia
Krav
Krav posted this 18 April 2016
Hi Olivia,
Thanks for the response very helpful.
At the moment I do not have a green 'add to page' button under the 'Insert' dropdown, only the 'add to Template'. How can I access the 'add to page' button to insert sections into CMS Content? I've tried adding a new template and opening a new file, but no luck with the add to page icon!
Regards Krav
Hi Olivia, Thanks for the response very helpful. At the moment I do not have a green 'add to page' button under the 'Insert' dropdown, only the 'add to Template'. How can I access the 'add to page' button to insert sections into CMS Content? I've tried adding a new template and opening a new file, but no luck with the add to page icon! Regards Krav
Support Team posted this 19 April 2016
Make sure that the content is enabled on the template, check it under the Layout >> Content and Sidebars.
Hi, Make sure that the content is enabled on the template, check it under the Layout >> Content and Sidebars. Sincerely, Hella
Krav
Krav posted this 19 April 2016
Hi Hella,
The content is enabled under the >>Content and Sidebars, but no 'Add to Page' button.
I have installed a clean theme and just put a header and image on. I would like to then import 'Sections' from Themler below the image, but the content for these would need to be visible in WP editor.
I have included the theme .zip below so that you can see what I currently have and then hopefully you can instruct me as to how to proceed - thanks.
Best regards
Krav
Hi Hella, The content is enabled under the >>Content and Sidebars, but no 'Add to Page' button. I have installed a clean theme and just put a header and image on. I would like to then import 'Sections' from Themler below the image, but the content for these would need to be visible in WP editor. I have included the theme .zip below so that you can see what I currently have and then hopefully you can instruct me as to how to proceed - thanks. Best regards Krav
Support Team posted this 21 April 2016
Please enable this option and make sure that your WP front page is a Single Page:
Hi, Please enable this option and make sure that your WP front page is a Single Page: !enable-content-2.png! Thank you, Olivia
