I installed Themler on a virtualized W8 OS on my iMac.
This solution is not adapted.
How can I move the licence on a PC ?
If you would like to use Themler Desktop for Windows, just sign in in Themler. It should recognize your license automatically after this.
thank you very much for this quick answer. I'll do that.
Is there another solution than "Themler Desktop for Windows" to use the software on a PC ?
How to use it on a Mac ?
To use Themler, there are several options:
1. Install Themler. At themler.com click "Download Now" and choose a corresponding option - Themler for Windows or Themler for Mac. Just sign in, select CMS and create a theme. You can export a theme at any time as .zip and install in your CMS and continue working at it.
2. Download default theme .zip via themer.com >> Download Now >> choose CMS and click "Themler for [CMS name]" and install it in your CMS. Then select "Themler" in CMS admin and work at the theme.
thanks for helping.
Your explanation was fine.
All works as designed.
You can close the ticket.
