Virtuemart, no content when using cart extension
shopmods
shopmods posted this 15 April 2016
Hi all,
after enabling VP one page checkout from virtueplanet, the frame between header and footer just returns blank.
There is no content output at all. Show cms content is enabled in Themler.
I have tried other cart extensions aswell, same result.
Works fine with the default joomla template.
Is it not possible to use a different cart?
Any idea?
Thanks already!
Hi all, after enabling VP one page checkout from virtueplanet, the frame between header and footer just returns blank. There is no content output at all. Show cms content is enabled in Themler. I have tried other cart extensions aswell, same result. Works fine with the default joomla template. Is it not possible to use a different cart? Any idea? Thanks already!
Support Team posted this 15 April 2016
Please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at an time.
Please let us know if the issue is still present.
Hello, Please try updating to the latest Beta version. You may need to check the box next to "Get Beta updates" in your profile to receive the Beta update notification. After installing the Beta update you may uncheck the box at an time. Please let us know if the issue is still present. Sincerely, Nettie, BillionDigital Team
shopmods
shopmods posted this 19 April 2016
Seems to be working now, thanks.
One more problem though, is that the cart link does not dynamically update when I delete products from within the cart overview.
Is this caused by the cart extension I am using?
Seems to be working now, thanks. One more problem though, is that the cart link does not dynamically update when I delete products from within the cart overview. Is this caused by the cart extension I am using?
Support Team posted this 21 April 2016
Does the issue happen with the default Joomla theme?
Unfortunately we cannot test this extension on our side because it's commercial component.
Hi, Does the issue happen with the default Joomla theme? Unfortunately we cannot test this extension on our side because it's commercial component. Thank you, Olivia
shopmods
shopmods posted this 21 April 2016
Hey,
I have not tested it to be honest as I purchased a different module for a minicart which works outstanding.
You can close this topic.
Thanks!
Hey, I have not tested it to be honest as I purchased a different module for a minicart which works outstanding. You can close this topic. Thanks!
