Themler v.289 Update (16-April-2016)
Support Team posted this 15 April 2016
Hi everyone,
We've updated Themler from the current Beta version.
The new version is 289.
Here is a list of fixes included in this Themler update:
Controls
General
  • Layout switched to 12 columns instead of old 24 columns
  • Drupal: Now Blog template is used for Drupal native Blogs.
UI Improvements
  • Distinct theme structure with colors:
    • Orange frames: Header & Footer for all templates
    • Blue frames: Controls of current template
    • Green frames: CMS content controls
  • Different buttons for Adding section to Template and to CMS content (see screenshot above)
  • Join Text editing commands in context toolbar and on Home tab, depending on selection in Text editing area:
    • By default, text styles are applied to Section styles, or to specific control where value is already customized
    • When all text is selected then the style changes will be applied to selected control
    • If text fragment is selected then changes will be affected by html markup (e.g. with <b> and <i> tags)
  • Drag & Drop improved: if multiple drop containers are located near each other then they will be joined into single drop area. After the drop you will see the popup with list of drop containers to choose from.
  • Ribbon UI: Lock function for images to resize proportionally:
  • Ribbon UI: Button for replace any section with different preset:
  • UI: Added button for more easy hide and show of left (navigation) and right (property editor) panels
Fixes
  • Ribbon UI: Fixed issue with absence of control's tab on ribbon if the control is located inside Section with Columns
  • Ribbon UI: Fixed problem when working with inherited columns
  • Ribbon UI: Fixed issue with empty Font Family on the Home tab
  • PrestaShop: Fixed issue with Columns width
  • PrestaShop: Fixed issue with Product Title in Accessories
  • VirtueMart: Fixed issue with adding Cart Link control
  • VirtueMart: Fixed issue with accessing Products templates in some cases
  • VirtueMart: Fixed issue with Amount Counter
  • Joomla: Fixed "Not found Error" when opening theme in Themler
  • Joomla: Fixed issue with Default template
  • Joomla: Fixed issue with JSN-Uniform
  • Drupal: Fixed issue with Sidebars and empty Drupal Regions
  • Other fixes of bugs and crashes.
Themler Team
Hi everyone, We've updated Themler from the current Beta version. The new version is 289. Here is a list of fixes included in this Themler update: [post:73883] Thank you, Themler Team
28 Comments
DouzanStudio
DouzanStudio posted this 15 April 2016
Major updates makes me back!
Testing the updates..Thanks guys <3></3>
Major updates makes me back! Testing the updates..Thanks guys &lt;3&gt;&lt;/3&gt;
wesley.talbott
wesley.talbott posted this 15 April 2016
Cannot redeclare class CustomCurrency - Joomla
Cart link was working fine, now it is broken with the attached error.
Cannot redeclare class CustomCurrency - Joomla Cart link was working fine, now it is broken with the attached error.
BORN TO BE WEB
BORN TO BE WEB posted this 16 April 2016
Please fix logo menu in french "Hauteur et Largeur"
BORN TO BE WEB
"Wordpress"
Bug by editing the logo on tablet not resize. it's ok smartphone, PC and laptop
"Wordpress" Bug by editing the logo on tablet not resize. it's ok smartphone, PC and laptop
Stagger Lee posted this 16 April 2016
I like new thing with left-right sidebars. I like I can control it. Before it was wild and showed when not asked to show.
QAAF Tech
QAAF Tech posted this 16 April 2016
I've downloaded latest version, un-installed previous version and now using v 289.
When I create new theme, it shows v 256 and says update available. Is it a bug?
As it asks me to update everytime i try to create new theme (html)
When i open (html) theme (v289) it says please wait, theme is being updated to latest version and after a while it says theme was updated to the new version (v289).
It does it everytime.
I've downloaded latest version, un-installed previous version and now using v 289. When I create new theme, it shows v 256 and says update available. Is it a bug? As it asks me to update everytime i try to create new theme (html) When i open (html) theme (v289) it says please wait, theme is being updated to latest version and after a while it says theme was updated to the new version (v289). It does it everytime.
Vitaliy WD
Vitaliy WD posted this 16 April 2016
Crash when set Bold option for Button font (on any template even blank theme).
Tested on Joomla and WP.
Crash when set Bold option for Button font (on any template even blank theme). Tested on Joomla and WP.
n2417
n2417 posted this 17 April 2016
Working on wordpress themes, each time I run the update, the theme layout crashes and it is not possible to get the same design from themler to appear on the website :/
letstalklocal
letstalklocal posted this 17 April 2016
Why Change with "Layout switched to 12 columns instead of old 24 columns"
I liked the granular of control of the column size. What happens if I had a site where I had a 19 - 5 column.
Why Change with "Layout switched to 12 columns instead of old 24 columns" I liked the granular of control of the column size. What happens if I had a site where I had a 19 - 5 column.
s.lichtenwimmer
s.lichtenwimmer posted this 17 April 2016
"Joomla"
All my Slides except the first one are white and empty.
In themler itself there are all images visible.
"Joomla" All my Slides except the first one are white and empty. In themler itself there are all images visible.
frederic11
frederic11 posted this 17 April 2016
Yep, same problem in Joomla, see here : https://answers.themler.com/questions/74180/latest-version-16-april-break-my-site-when-update
And modules position are out too...
Yep, same problem in Joomla, see here : https://answers.themler.com/questions/74180/latest-version-16-april-break-my-site-when-update And modules position are out too... Regards
Hi guys,
Please report issues in a separate topics. It's difficult to support each issue in one topic.
Thank you. We'll fix it.
We'll check this issue.
I've failed to reproduce this issue on my side. Could you please create separate Private topic and attach the theme with the problem button.
In general, you don't need to re-install Themler to get the latest version of Themler. The Themler version in Desktop may be different from the current Themler version because we update Themler more often than Desktop. To get the latest Themler version you just need to update the theme. So, if you updated theme and the update was successful then it's ok. If you updated theme to v.289, saved it and reopened and it still asks for update to v.289 then it's not ok and you should create a new Private topic and attach the problem theme.
They will be converted to 10-2.
Please create a Private topic and attach a theme backup.
I'll check this topic.
Please create a Private topic and provide the access to the Joomla admin panel.
Hi guys, Please report issues in a separate topics. It's difficult to support each issue in one topic. > Please fix logo menu in french "Hauteur et Largeur" Thank you. We'll fix it. > Bug by editing the logo on tablet not resize. it's ok smartphone, PC and laptop We'll check this issue. > Crash when set Bold option for Button font (on any template even blank theme). Tested on Joomla and WP. I've failed to reproduce this issue on my side. Could you please create separate Private topic and attach the theme with the problem button. > I've downloaded latest version, un-installed previous version and now using v 289. When I create new theme, it shows v 256 and says update available. Is it a bug? As it asks me to update everytime i try to create new theme (html) When i open (html) theme (v289) it says please wait, theme is being updated to latest version and after a while it says theme was updated to the new version (v289). It does it everytime In general, you don't need to re-install Themler to get the latest version of Themler. The Themler version in Desktop may be different from the current Themler version because we update Themler more often than Desktop. To get the latest Themler version you just need to update the theme. So, if you updated theme and the update was successful then it's ok. If you updated theme to v.289, saved it and reopened and it still asks for update to v.289 then it's not ok and you should create a new Private topic and attach the problem theme. > What happens if I had a site where I had a 19 - 5 column. They will be converted to 10-2. > All my Slides except the first one are white and empty. In themler itself there are all images visible. Please create a Private topic and attach a theme backup. > https://answers.themler.com/questions/74180/latest-version-16-april-break-my-site-when-update I'll check this topic. > Working on wordpress themes, each time I run the update, the theme layout crashes and it is not possible to get the same design from themler to appear on the website Please create a Private topic and attach a theme backup. > Cannot redeclare class CustomCurrency - Joomla Cart link was working fine, now it is broken with the attached error. Please create a Private topic and provide the access to the Joomla admin panel. Thank you, Olivia
letstalklocal
letstalklocal posted this 18 April 2016
What is wrong with keeping the 24 vs 12 column sizes? This messes up the sizes of my layout if I update the theme?
sibren
sibren posted this 18 April 2016
Why changing the columns from 24 to 12?
Now I need to change all articles in all my website where I have used Bootstrap column classes, and that's a lot!!
Can't you make it a general setting if you really want to provide 12 column grids?
Why changing the columns from 24 to 12? Now I need to change all articles in all my website where I have used Bootstrap column classes, and that's a lot!! Can't you make it a general setting if you really want to provide 12 column grids?
letstalklocal
letstalklocal posted this 19 April 2016
I have an issue with columns in the themler UI...it keeps putting a "column is empty" message even though column is not empty...I fresh and it goes away, I move to another page and it comes back I think we are going a bit backwards in the UX. Everything was easy to find before. It made sense when you click on something and the settings where there, now half the time I have to go into "more options" to find things. Not loving the lastest changes.
support12
support12 posted this 19 April 2016
New Release is ok and good but still there is major problem.
1) Themler has given option to edit all pages through themler suppose if you need to edit your about us page you can do it but there was options to insert into page button but now is is vanished.
2) When you insert footer from section it says - Sorry you website will restore now - Error this is very critical problem I have faced with new updates.
New Release is ok and good but still there is major problem. 1) Themler has given option to edit all pages through themler suppose if you need to edit your about us page you can do it but there was options to insert into page button but now is is vanished. 2) When you insert footer from section it says - Sorry you website will restore now - Error this is very critical problem I have faced with new updates.
maurizios746
maurizios746 posted this 19 April 2016
Themler for joomla v289 does not load images from files
Scorpion Computers & Software
Scorpion Computers & Software posted this 19 April 2016
I love the fact that we now use 12 columns instead of 24. Most CMS-ses and other webdevelopment tools use the default Bootstrap. Also a lot of extensions for CMS-ses use the default bootstrap and they only use 12 cols.
I did however have a problem with sites that make use of the shortcodes. These Joomla websites now give the content of the article instead of what should happen with the shortcodes.
I love the fact that we now use 12 columns instead of 24. Most CMS-ses and other webdevelopment tools use the default Bootstrap. Also a lot of extensions for CMS-ses use the default bootstrap and they only use 12 cols. I did however have a problem with sites that make use of the shortcodes. These Joomla websites now give the content of the article instead of what should happen with the shortcodes.
shopmods
shopmods posted this 20 April 2016
Same here. VERY annoying!!
> Cannot redeclare class CustomCurrency - Joomla > > Cart link was working fine, now it is broken with the attached error. Same here. VERY annoying!!
Support Team posted this 21 April 2016
We've updated Themler to v292 and resolved the reported issues with missing controls and issue with opening from file on Themler Desktop for MAC.
If you have any issues with this update please create a new Private topic and provide more details about the issue, attach problem theme or provide access to the joomla admin panel.
Hi, We've updated Themler to v292 and resolved the reported issues with missing controls and issue with opening from file on Themler Desktop for MAC. If you have any issues with this update please create a new Private topic and provide more details about the issue, attach problem theme or provide access to the joomla admin panel. Thank you, Olivia
