Hi everyone,
We've updated Themler from the current Beta version.
The new version is 289.
Here is a list of fixes included in this Themler update:
Controls
- Added Form Control
General
Layout switched to 12 columns instead of old 24 columns
Drupal: Now Blog template is used for Drupal native Blogs.
UI Improvements
Distinct theme structure with colors:
- Orange frames: Header & Footer for all templates
- Blue frames: Controls of current template
- Green frames: CMS content controls
Different buttons for Adding section to Template and to CMS content (see screenshot above)
Join Text editing commands in context toolbar and on Home tab, depending on selection in Text editing area:
- By default, text styles are applied to Section styles, or to specific control where value is already customized
- When all text is selected then the style changes will be applied to selected control
- If text fragment is selected then changes will be affected by html markup (e.g. with
<b>and<i>tags)
Drag & Drop improved: if multiple drop containers are located near each other then they will be joined into single drop area. After the drop you will see the popup with list of drop containers to choose from.
Ribbon UI: Lock function for images to resize proportionally:
Ribbon UI: Button for replace any section with different preset:
UI: Added button for more easy hide and show of left (navigation) and right (property editor) panels
Fixes
- Ribbon UI: Fixed issue with absence of control's tab on ribbon if the control is located inside Section with Columns
- Ribbon UI: Fixed problem when working with inherited columns
- Ribbon UI: Fixed issue with empty Font Family on the Home tab
- PrestaShop: Fixed issue with Columns width
- PrestaShop: Fixed issue with Product Title in Accessories
- VirtueMart: Fixed issue with adding Cart Link control
- VirtueMart: Fixed issue with accessing Products templates in some cases
- VirtueMart: Fixed issue with Amount Counter
- Joomla: Fixed "Not found Error" when opening theme in Themler
- Joomla: Fixed issue with Default template
- Joomla: Fixed issue with JSN-Uniform
- Drupal: Fixed issue with Sidebars and empty Drupal Regions
- Other fixes of bugs and crashes.
Themler Team
