Using Themler Sections and Text not appearing in WP Visual Editor - can anyone help!
Krav
Krav posted this 18 April 2016
I'm creating a website using Themler 'Sections', then editing text and images as necessary. This is a one page website with the first page having an overall image, then underneath this multiple sections running down the page imported from Themler gallery.
At the moment there is no corresponding titles, text or image code appearing in my WP admin 'visual / text editor' panel?
Am I doing anything wrong - as I just click on the 'Add Section' button then import the section from the Themler gallery? Do I need to do anything extra to get copy into WP? Should the 'Sections', as they are Themler generated and have short-codes enable content to appear in WP Visual / text editor anyway?
I'm currently stuck and do not want to move forward until I've identified how to get content across to WP!
Any help would be very welcome.
Cheers Krav
Hi, I'm creating a website using Themler 'Sections', then editing text and images as necessary. This is a one page website with the first page having an overall image, then underneath this multiple sections running down the page imported from Themler gallery. At the moment there is no corresponding titles, text or image code appearing in my WP admin 'visual / text editor' panel? Am I doing anything wrong - as I just click on the 'Add Section' button then import the section from the Themler gallery? Do I need to do anything extra to get copy into WP? Should the 'Sections', as they are Themler generated and have short-codes enable content to appear in WP Visual / text editor anyway? I'm currently stuck and do not want to move forward until I've identified how to get content across to WP! Any help would be very welcome. Cheers Krav
Support Team posted this 21 April 2016
Hello Krav,
let me provide some explanation about content. The Sections which are located directly inside Content & Sidebars mean that these Sections are stored in theme, as part of static theme design. And they will be displayed on every page which is using current template.
The Sections which are located inside Post Content control are dynamic content of the current page. And this Section is stored in WP post/page. This Section is not displayed on other pages.
So if Sections are added as part of Template, their content cannot be accessed from WP admin back end. It could be edited in Themler only
Hello Krav, let me provide some explanation about content. The Sections which are located directly inside Content & Sidebars mean that these Sections are stored in theme, as part of static theme design. And they will be displayed on every page which is using current template. The Sections which are located inside Post Content control are dynamic content of the current page. And this Section is stored in WP post/page. This Section is not displayed on other pages. So if Sections are added as part of Template, their content cannot be accessed from WP admin back end. It could be edited in Themler only Regards, Aileen
Krav
Krav posted this 21 April 2016
Thank you for the information Aileen.
Regards Krav
Thank you for the information Aileen. Regards Krav
Support Team posted this 22 April 2016
You are welcome. Let us know if you need any further help.
You are welcome. Let us know if you need any further help. Sincerely, Hella
